My Turbo Build.
Old Aug 26, 2010 | 02:58 PM
  #51
rtspeedemon's Avatar
rtspeedemon
Ah 5 speed :-) Confuscious say that is totally different animal.
Old Sep 15, 2010 | 05:10 PM
  #52
Hahns5.2's Avatar
Hahns5.2
As of yesterday my truck is officially running on Megasquirt now!
Old Sep 15, 2010 | 05:26 PM
  #53
Crazy4x4RT's Avatar
Crazy4x4RT
That cool! How hard was it? Anything special to wire it all up? Would you be able to do a write up on it?
Old Sep 15, 2010 | 07:15 PM
  #54
Applehugger's Avatar
Applehugger
Originally Posted by shadowthedakota
it was a joke...they do make an awesome sound, though.
Yeah they do. Love that whine :-)
Old Sep 15, 2010 | 11:33 PM
  #55
JGC403's Avatar
JGC403
MS-I or MS-II?
Old Sep 16, 2010 | 12:02 AM
  #56
Hahns5.2's Avatar
Hahns5.2
Pretty damn simple really. Actual time spent wiring was under 3 hours. I do have a noise problem when I approach 3k RPM that I'll have to fix, could easily be bad grounds or something. Tuning is a fairly steep learning curve. Once I get it going better I may be able to do a write up.
Originally Posted by JGC403
MS-I or MS-II?
MS-II/Extra
Old Sep 16, 2010 | 01:13 PM
  #57
JGC403's Avatar
JGC403
How did you do the trigger wheel for the crankshaft? Did you use the stock crank position sensor, or something else?
Old Sep 16, 2010 | 03:29 PM
  #58
Hahns5.2's Avatar
Hahns5.2
Should have clarified I'm running fuel only. Went the MS2/Extra route for the 16x16 VE table.
Old Sep 16, 2010 | 05:02 PM
  #59
JGC403's Avatar
JGC403
Doesn't the MS still need a crank signal, to know when to start running the injectors?
Old Sep 16, 2010 | 05:07 PM
  #60
Hahns5.2's Avatar
Hahns5.2
It can use a bunch of different signals, I'm simply using the negative coil wire.
