My Turbo Build.
Old Sep 28, 2010 | 05:24 PM
  #71
kikazzdakota's Avatar
kikazzdakota
dude bov on the passengers side would be fun! i could see me getting in trouble with that nice build dude
Old Sep 30, 2010 | 10:00 PM
  #72
nborga87's Avatar
nborga87
what all have you done to the fuel system (injectors, fuel pump, regulator, etc) and also the pcm? I ve got an H1c that i took off my pullin truck that may be a good use for it!
Old Sep 30, 2010 | 11:05 PM
  #73
Hahns5.2's Avatar
Hahns5.2
Stock fuel pump, no regulator on this system, stock injectors (will be going to 42lb injectors within a couple weeks), Mopar PCM controls ignition and IAC, Megasquirt is running the injectors, BTM retards timing.
Old Oct 4, 2010 | 11:29 PM
  #74
gladiator's Avatar
gladiator
have you had any issues with the plenum base gasket sealing with the boost you are making?
Old Oct 5, 2010 | 12:09 AM
  #75
Hahns5.2's Avatar
Hahns5.2
I ditched the Kegger a long time ago for a M1 manifold....
Ordered my 42lb injectors today!
Old Oct 5, 2010 | 12:44 AM
  #76
Crazy4x4RT's Avatar
Crazy4x4RT
Just so I don't hijack the other guys thread more I will post it in here.
Originally Posted by Hahns5.2
Not really, I doubt they could make the PCM compatible with boost, Megasquirt's cheaper anyways and I don't have to send it off to have it tuned..
Yes they do have a flash for boost, as well as any specs you want. But your probably right on the price.
http://www.bgperformancepcm.com/#magnum
B&G Supercharged Truck Flash (92-95 SBEC) (96-03 JTEC) - $350 flashed PCM or Flashed into Handheld ($650) includes shipping (Ground) (*)
This PCM upgrade is designed for vehicles that have installed a supercharger that require a custom timing control once vehicle goes into boost.
Revised premium fuel & timing tables (accommodate supercharger)
Shift points raised 5800 rpm
Rev limit raised 6500 rpm
Torque management removed
Speed limit raised 140 mph
Custom 2 bar map sensor calibrations available – Call for Details
Note: Call for pricing on 92-95 SBEC
B&G Custom Truck Flash (92-95 SBEC) (96-03 JTEC) - $400 Flashed PCM or Flashed into Handheld ($650) includes shipping (Ground) (*)
This PCM upgrade is designed for the customer who provides his own specifications for fuel and timing, shift points, rev limit, and speed limit settings or packages that are not
factory engine/trans options.
Revised timing & fuel tables (per customer request)
Shift points (per customer request)
Rev limit (per customer request)
Speed limit raised but not removed (per customer request)
B&G Custom Truck Live on-the-Fly Tuning (In House-Tuning)(92-95 SBEC/96-06 JTEC) - $750-$1200 depends on the amount of instrumentation required to custom tune
This PCM upgrade is designed for the customer who wants his own vehicle custom tuned for optimal output and customization based on vehicle modifications
Revised timing & fuel tables ( custom live on-the-fly tuning to optimize tables) Note: insure vehicle has correct octane fuel blend for optimal tuning
Shift points raised
Rev limit raised
Torque management Removed
Speed limit raised
Old Oct 5, 2010 | 03:06 AM
  #77
luthoro's Avatar
luthoro
That ^^^ is very good information
Old Oct 5, 2010 | 11:24 AM
  #78
JGC403's Avatar
JGC403
What sensors were you able to share with the stock computer and the MS-II? I'm trying to figure that out right now. I think the TPS and the MAP sensors can be shared. What about the Coolant temp and air temp? I think that is all of them except for the O2 and the crank position sensor and those are going to be dedicated to the MS for my setup.
Old Oct 5, 2010 | 12:25 PM
  #79
Hahns5.2's Avatar
Hahns5.2
The only thing I'm sharing is the TPS. No need to share the MAP, the MS has it's own 2.5 BAR MAP sensor. The CLT and IAT sensors can be shared but you have to do something with a couple resistors on the board and set some corrections in the software. I just chose to weld a bung in my cold side for the GM IAT and the GM CLT is in a T spliced in the heater hose.
Old Oct 5, 2010 | 09:27 PM
  #80
JGC403's Avatar
JGC403
I wanted to run 2 MAPs so I could do the continuous barometric correction.
