Fuel Pump / Filter?
Fuel Pump / Filter?
After dropping off grandma for the July 4th stuff.. the truck died like out of gas.
I can still hear the pump pressurize before starting the engine.. it will start but won't idle. I can drive for small distances but only if the pedal is floored, it won't idle.
it is a '95 Dakota SLT 4x4 with a 5.2L.
Any ideas?
Dave
Any ideas?
Dave
update!
ok I went to where it broke down and it started right up... was able to drive 7 miles and then it started dying.
the speedometer and tach drop to zero even while doing 55 as if the whole cluster looses power and the whole while the engine acts like it's dying or has no fuel. eventually it won't run at all until it cools off again....
so once again, any ideas?
ok so I got it all tore down, someone has already performed the power junction repair. I did notice that if I remove and then replace the ASD relay the truck will start back up, so I swapped the relay from the A/C unit in an effort to test it. I didn't make it 100 feet before it died again.
Also when we towed it, I noticed that the speedometer did not function at all, I know it is not cable driven, but shouldn't it still function when moving?
another side note, is it possible there is something cause the ASD to trigger? the fuel gauge has been stuck at full since I bought the truck and I just assumed a sending unit problem, but saturday it began to function again, well it worked until it hit 3/4 full and then got stuck again....
Through all of this I am assuming it is something electrical.
Any clue?
Any clue?
on
1 Post
