Automatic transmission question
Old 06-03-2018, 02:29 PM
2jammer's Avatar
2jammer
2jammer is offline
I appreciate the offer, but I'm in Nevada!
Old 06-03-2018, 02:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,269 Likes on 3,016 Posts
Originally Posted by 2jammer
i appreciate the offer, but i'm in nevada!
road trip!!!!! :d
Old 06-03-2018, 02:45 PM
tbugden's Avatar
tbugden
tbugden is offline
Ah yeah that's a bit of a haul lol. And CT ain't exactly a vacation destination either. We got trees and lots of glacial geology.
Old 06-03-2018, 02:54 PM
RalphP's Avatar
RalphP
RalphP is offline
Well, there's the temps in Nevada vis the temps in CT ...
RwP
Old 06-04-2018, 07:04 PM
SRAC76's Avatar
SRAC76
SRAC76 is offline
Originally Posted by RalphP
NOT for a 1993; those are all RH's.
The REs weren't used in Dakotas until 1996, when the JTEC replaced the SBEC and OBDII came available.
47RE goes with the 4.7, not the Magnum blocks.
RwP
Again just had it replaced I know what it was... 47RE but whatever what do I know it is running and no problems with the transmission.
Old 06-04-2018, 11:25 PM
2jammer's Avatar
2jammer
2jammer is offline
The plot thickens-
I went to Dodge's website: https://www.dodge.com/webselfservice/dodge/index.html
Entered my VIN. It says it doesn't work for trucks older than 1998 but I rolled the dice, entered my VIN and got:
Now if I scrolled down a bit further to options I get:
So SRAC76, I'm not doubting you- but it's looking like I won't know what I have until I put eyes on it.
Old 06-04-2018, 11:42 PM
tbugden's Avatar
tbugden
tbugden is offline
FWIW, I ran the VIN for my '95 parts truck and it shows the same tranny - 46RH
Old 06-04-2018, 11:46 PM
volaredon's Avatar
volaredon
volaredon is offline
every 92/93 factory V8 truck I have seen or worked on (there have been a BUNCH!!!) has been a 46 RH, AKA 518.... V6s were the A500/ 42 or 44 RH..... SOME V8s got these later.but not all. the 46 is a heavier duty trans BUT the OD section between them is IDENTICAL/ only difference there has to do with 2wd or 4wd.
and again the RE series did not come out until the 96 model year!!! RH means hyd controlled governor... RE means electronic (computer) control governor. one less headache to worry about pre 96. externally the trannys are very much alike between an RH and an RE. the biggest difference is a 3 pin or 7 pin connector on driver side (NOT talking about neutral safety switch here!)
Old 06-05-2018, 08:18 PM
HeyYou is offline
And on top of that, the 47R? won't even bolt up to a 3.9, 5.2, or 5.9 gas. It was behind the diesel, or the V-10, neither of which ever found their way into a dakota. (from the factory.....)
He has a 46RH at best.
Quick Reply: Automatic transmission question
