Quick brake bandaid?
So I've been battling a brake leak recently of the rear brake splitter mounted on the diff (rubber hose is leaking) and as I was pulling line off I realized there is an alarmingly large hole in the brake line that goes to the hose/splitter. It's the main line that runs to the booster/front and is behind the fuel tank (for easy and convenient removal). Is there any sort of bandaid I can do to get me through a few days till I can get it in a brake shop? I've thought about crimping the end where it's leaking with some pliers. Front brakes still work so it's still drivable but I don't trust it much anymore. Other Dakota is KIA until further notice so this is what I need to drive (20 miles into town)
I agree,
You can even buy it in lengths from 8in. to 60 or so and then add a coupling to extend it on. FWIW I believe it ends on the frame about 2-3 feet from the front wheel. You should see a block there that it ties too.
But if it's rusted into there, its probably weak on up the frame.
Just for clarification, This is the brake booster. and its mounted to the fire wall
https://www.ebay.com/itm/Power-Brake...2:pf:0&vxp=mtr
This is a universal proportioning valve, mounted on the frame. About 2-3 feet from the front wheel.
https://www.ebay.com/itm/Universal-G...5:pf:0&vxp=mtr
I believe the brake line only goes from the real axle to this valve. Again, you can run it beside the the old line and tie as you can, ie wire ties etc,
An no, you cannot use a bolt to plug it. It is a flare fitting.....
Trending Topics
On an 89, he may have it easier; for 1988, they had a load sensitive proportioning valve in front of the front spring mount for the rear leaf spring (the front, rear spring mount. Heh. THAT sounds confusing!)
He'll only need to run to that for now.
I'd also replace from there to the front combination valve as soon as possible.
Since it's easier to reach with the bed off, I'd also plan on rebuilding the fuel pump, replacing ALL the rubber back there, etc.
But it's not my truck
RwP
RwP
