Transfercase exploded
Old Apr 4, 2019 | 11:13 PM
NoDakDakota's Avatar
NoDakDakota
Default Transfercase exploded
Anyone know if there is a difference between one from a auto or a manual. Just bought this truck like this. 95 3.9 5spd
Old Apr 5, 2019 | 07:40 AM
93 ragtop's Avatar
93 ragtop
OUCH!!!
According to Rockauto, 94-96 transfer case are the same..... manual or auto.
Old Apr 5, 2019 | 12:02 PM
I bet it doesn't work very well like that........
Old Apr 5, 2019 | 01:13 PM
Kahless's Avatar
Kahless
You can use a newer one with some messing about. I have a 98 case on my truck. The newer cases have better internals for shifting on the fly at higher speed. You need to mess with some vacuum stuff to get it to function properly but it wasn't too bad.
Old Apr 5, 2019 | 07:24 PM
Need that VSS on the tailshaft of the t-case though, that's where the 95 gets its speedometer reading from. 98 and up won't have it.
Old Apr 5, 2019 | 07:51 PM
Kahless's Avatar
Kahless
Yeah you do. When I did mine I disassembled both and mixed and matched pieces to make it work. The T case I had on hand from a full sized 98 ram was basically the same case minus some ports, so I mostly swapped the guts out of the one into my case which was still good with bad internals.
Old Apr 6, 2019 | 12:34 AM
NoDakDakota
Well I'm hoping I found one today coming all the way from Wisconsin to Bismarck ND. Wasnt sure if the tcase off of my parts 96 ram 1500 would fit or not its behind a auto
Old Apr 6, 2019 | 11:17 AM
Kahless's Avatar
Kahless
As long as the sensors are all the same the T cases from both auto/manual bolt on the same. They're interchangeable. It would depend on the sensor differences between the ram and dakota cases. The 98 ram one I used had a bunch of different vacuum stuff on it.
There should be a round tag on the case with a stamped number on it. If that matches your case then it's the same internally and the sensors should be the same.
Old Apr 6, 2019 | 05:53 PM
NoDakDakota
Default Well old is out
Old Apr 6, 2019 | 05:55 PM
Kahless's Avatar
Kahless
That is really a thing of beauty.
