Brakes
Old 10-17-2021, 09:59 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
I would recheck it after getting all the lines done, and brakes bled. Step HARD on the pedal a couple times, and the shoes will center themselves where they need to be. At which point, you will likely need to adjust them. (tighter....)
  #92
Old 10-17-2021, 11:47 AM
bronze's Avatar
bronze
bronze is online now
Originally Posted by HeyYou;[url=tel:3527418
3527418[/url]]I would recheck it after getting all the lines done, and brakes bled. Step HARD on the pedal a couple times, and the shoes will center themselves where they need to be. At which point, you will likely need to adjust them. (tighter....)
10-4. Was hoping for an answer like that.
  #93
Old 10-17-2021, 05:56 PM
bronze's Avatar
bronze
I’m old.
  #94
Old 10-18-2021, 10:11 AM
HeyYou is offline
Originally Posted by bronze
I’m old.
Yep. Me too.
  #95
Old 10-18-2021, 06:12 PM
bronze's Avatar
bronze
I don’t like making brake lines. Worse, I like the flaring tool even less. I’m done making brake lines. They’re all installed. No gas in my butt to bleed them tonight. Tomorrow. Just hoping they don’t leak. Wont be surprised if they do.
My advice to anyone doing brake lines: spend dough on a good quality flare tool. These cheap $20 - $40 ones are suspect at best.
  #96
Old 10-18-2021, 07:30 PM
RalphP's Avatar
RalphP
RalphP is offline
Yep.
I used the Titan double flare tool for about $50; it worked a treat.
Those cheap ones? Are ... well, cheap crap.
Take a LOT more patience than I have at 65 ...
RwP
  #97
Old 10-18-2021, 07:39 PM
bronze's Avatar
bronze
I’m hoping I have no leaks Ralph. That cheap flaring tool doesn’t give me a warm n fuzzy feeling. I practiced like hell before actually using it on my lines. I improved to be sure but still not as good as it could be. That tool has limitations. If I have to rework them I’ll look at that Titan.
I’m assuming back-right, back-left, front-right, front-left in that order??? With Dodge one is never certain. Also thinking I may need to do them twice.
  #98
Old 10-18-2021, 08:08 PM
RalphP's Avatar
RalphP
RalphP is offline
That's how it works out, yes.
Logic is furthest ---> nearest to the master cylinder.
RwP
  #99
Old 10-18-2021, 08:26 PM
bronze's Avatar
bronze
Originally Posted by RalphP;[url=tel:3527554
3527554]That's how it works out, yes.
RwP
That’s how I learned it but I know of cases it doesn’t sequence that way. Who knows how they piped those cars. Probably has sumpin to do with global warming.
BTW, that Titan looks like the way to go.
  #100
Old 10-18-2021, 08:29 PM
RalphP's Avatar
RalphP
RalphP is offline
Knowing it's Mopar, it's more like "Was it put together by Charles with a red plaid shirt, Luis with the blue plaid shirt, or Charles with the green plaid shirt?"
Mopar used to be horrible about using umpteen part numbers for the exact same part, except it wasn't the exact same part ...
RwP
Quick Reply: Brakes
