Suspension Plus
Old Nov 16, 2021 | 10:07 AM
  #251
bronze's Avatar
bronze
Originally Posted by onemore94dak
Spare Parts
Or as my Dad would call them, "profits".
Old Nov 16, 2021 | 10:09 AM
  #252
onemore94dak's Avatar
onemore94dak
Even funnier !
Old Nov 16, 2021 | 10:10 AM
  #253
bronze's Avatar
bronze
Even funnier !
Wish I knew what they are supposed to be for. I'd like to modify one of those washers for one that is missing on my upper control arm...if it works.
Old Nov 16, 2021 | 10:40 AM
  #254
onemore94dak
I'm guessing here but under the castle nut? or possibly these ball joints have more than one use and those washers go on the other vehicle/s they fit.
Old Nov 16, 2021 | 04:34 PM
  #255
bronze's Avatar
bronze
Why does my '93 Dodge have some SAE and some metric? Grrrrr!!
Old Nov 16, 2021 | 08:16 PM
  #256
RalphP's Avatar
RalphP
Because.
It was made during the swap from SAE to metric for everything.
And some replacement for SAE sized parts are now metric.
RwP
Old Nov 17, 2021 | 12:50 PM
  #257
tndakman's Avatar
tndakman
If it's any consolation to you my '92 model year was the same way--part metric part sae.
Old Nov 17, 2021 | 01:01 PM
  #258
bronze's Avatar
bronze
It’s a little frustrating. You put an SAE socket on a bolt head and it feels snug (especially with a little crud around the bolt head) only to find out it’s a metric that is a perfect fit. Oh, well. It is what it is. Just got to remember we have bi-sexual trucks and proceed accordingly. It’s when you assume everything is SAE when you get in trouble.
Old Nov 17, 2021 | 01:22 PM
  #259
bronze's Avatar
bronze
OK Ralph, here is where you could potentially be of most use. I’m asking a lot of you to try and remember and on a model 5 years older that may not be exactly the same as mine. But here goes.
I see two basic approaches to getting that spring back in. One, attach the LCA first and go from there. Two, attach the LCA after the spring and LCA is lined up. The latter is what the FSM kinda suggests. They use two jacks…one at the outer side and one at the inner side of the LCA. Jack them up accordingly and fit the arm into the frame receivers, then bolt. I see merit with both methods.
Can you recall how you re-installed yours?
In the first method I mentioned (my current preferred method), can the spring be compressed enuf going thru the upper shock hole such that the LCA can pivot up to be square with the coil and no interference?
I’d rather not reinvent the wheel here when I have an experienced Dakota guy here.
Old Nov 17, 2021 | 01:26 PM
  #260
RalphP's Avatar
RalphP
That's where I used the compressor to reattach, yes.
It may have been a different model I rented; it was awkward fitting through the spring, but I managed to get the hooks through the spring. (Didn't care for how offset they were, but eh, it worked.)
I used the compressor to bring the spring up enough that I could attach the LCA/frame bolts first, then the spindle to the ball joint.
RwP
