Starter, Ign Switch, Key Cylinder, other...
Old Apr 3, 2023 | 07:27 PM
  #31
Lookin' good so far.
Old Apr 3, 2023 | 07:50 PM
  #32
bronze's Avatar
bronze
And speaking of getting quicker with repairs....a wiper linkage bushing failed today Probably the 6th or 7th time. Common problem with Chrysler products as we know. So gotta take off the wipers, cowling ,etc and replace the bushing. Took only about 30 minutes since I know what I'm doing. However, it came off again after I put everything back together. And I tested it before I put everything back together. Grrrr!
Old Apr 3, 2023 | 08:28 PM
  #33
I hate it when that happens.
Old Apr 3, 2023 | 10:29 PM
  #34
bronze's Avatar
bronze
Originally Posted by HeyYou;[url=tel:3564211
3564211[/url]]I hate it when that happens.
Had only 1 bushing so ordered a bunch more. Need 2. If I’m gonna tear into it again I’m gonna replace both.
Old Apr 4, 2023 | 02:55 PM
  #35
bronze's Avatar
bronze
Say HY, question. Why did Dodge add that wire from the battery ground terminal to that ground point on the core support (wire runs across the bottom of the photo)?
Old Apr 4, 2023 | 06:23 PM
  #36
Maybe provides a better ground path for some of the stuff on the front of the truck? They had some extra wire left? I am sure it serves a purpose, but, no real clue what that purpose actually is.
Old Apr 4, 2023 | 07:12 PM
  #37
bronze's Avatar
bronze
Originally Posted by HeyYou;[url=tel:3564270
3564270[/url]]Maybe provides a better ground path for some of the stuff on the front of the truck? They had some extra wire left? I am sure it serves a purpose, but, no real clue what that purpose actually is.
I like your extra wire theory.
Old Apr 5, 2023 | 12:00 PM
  #38
bronze's Avatar
bronze
TEST 2: PASS
Truck sat 2 days and she fired right up today, first try. 8 more tests to go.
Old Apr 11, 2023 | 01:19 PM
  #39
bronze's Avatar
bronze
TEST 3 & 4: PASS
I believe I know what my problem was. After cleaning off the starter terminals and putting everything back together I checked my battery connections one more time before shutting the hood. I noticed the main ground cable at the battery was slightly loose. It wasn't floppy loose but I could turn the lug about the bolt with some resistance. I say this because I also noticed my voltage gauge has steadied up. Prior, I was getting a bit of the shakies on the needle. Not all the time. Maybe a third of the time. Well, that's gone now. So that loose ground might have solved that problem too.
On one hand I'm kind of disgusted with myself for not seeing that ground cable. Caused me to take the time and effort to pull the starter. On the other hand, I'm not sorry I did that. I had a leaky valve cover that I repaired a year ago. Prior tho, it coated my starter with oil and sludgy crapola. The thing was a real mess. So I was able to clean it up good while I had it out. Also, while I was under the truck farting around with the starter I noticed a coolant leak from a loose hose clamp on one of the tranny coolant lines. So I cinched that up. Knew I had a leak but never found it until I was laying under the truck resting. Also, those starter connections were crusty so I'm glad I got them cleaned up too.
As for those battery terminals, I really like those clamp-style connections with the 4 bolts (and I didn't think I would). Makes for a real neat and organized battery terminal. I posted this picture a number of times but you can see what I'm talking about. However, if there is a flaw with them it's that the bolts come loose. I think I'm going to add a lockwasher to those bolts.
Old Apr 11, 2023 | 01:20 PM
  #40
bronze's Avatar
bronze
Check battery connections.
I did, but I didn't.
