96 3.9 AX-15 vs. 99 3.9 AX-15
Old 06-22-2018, 10:19 PM
96daksport's Avatar
96daksport
96daksport is offline
Default 96 3.9 AX-15 vs. 99 3.9 AX-15
Hi, is there a difference between 96 vs. 99 AX-15s for the 3.9? I am seeing them a lot cheaper and more readily available on Car-Part. Thanks in advance.
Old 06-23-2018, 08:45 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
I suspect the newer ones won't have the provision for the VSS in the output tailhousing. (2wd.)
Old 06-23-2018, 10:37 AM
96daksport's Avatar
96daksport
It looks like what appears to be a freeze plug is at the provision (picture below). Can that be knocked out and the VSS installed there? Thanks again.
Old 06-23-2018, 11:02 AM
HeyYou is offline
Maybe. Need to check the output shaft, and see if the drive gear is there, or if the shaft even has a provision for it. (my guesses would be no, and maybe.)
Old 06-23-2018, 12:51 PM
96daksport's Avatar
96daksport
Appreciate the help, this place has been super helpful for me progressing my V8 swap. I think I will just use the 96 AX-15 to avoid having to swap tailshafts etc. as I do not have a 3.9 AX-15 around for testing.
Old 07-16-2018, 12:37 AM
96daksport's Avatar
96daksport
One more question about this; does the VSS only send a signal to the speedometer or does it play other (more important) roles as well such as fueling, load, etc? Reason being these 97+ AX15s look very tempting at very low mileage. If it just feeds the speedometer I can use a GPS speedometer. Thanks again.
Old 07-16-2018, 05:09 AM
RalphP's Avatar
RalphP
RalphP is offline
It also sends speed info to the PCM, yes. Or so my understanding is.
It IS fed into connector B27 of the PCM for a 1996 Dakota.
RwP
Old 07-16-2018, 05:39 PM
96daksport's Avatar
96daksport
RwP
Fair enough, first gen AX-15 it is. Thanks again for the tech.
