Gear Problem! heeeelp
Old Aug 25, 2007 | 03:03 AM
JaymZz's Avatar
JaymZz
Default Gear Problem! heeeelp
hellloo dodgers
my reverse is useless! when ishift to R i hear the gears are shifting but, when i accelerate its like on N position but with a little reverse force...
i was driving my Durango '02 on offroad for a few minuts with the 4X4 high and low, as a practice, or i can say refreshthe suspention or sumthing.. anyway
i went for a walk, and i came back and started my car, i want to go reverse but.. nothing!! its like i shifted to N not to R!
So plzz any idea wuts the problem and wut coused that??
Old Aug 25, 2007 | 11:40 AM
JaymZz's Avatar
JaymZz
Default RE: Gear Problem! heeeelp
comooon guys its simple!
it shifts to R but theres no force, i accelerate but.. nothing like it was on N...
anyone???
maybe its a solenoid... clutch.. i dunno
the worst thing that my car just turned 67.000 km!! how bad are dodge trannys...
Old Aug 25, 2007 | 11:57 AM
master tech's Avatar
master tech
Site Moderator & Tech
I need to know if you have the 4.7 or 5.9 engine. either engine uses two diff transmissions.
Old Aug 25, 2007 | 11:58 AM
JaymZz's Avatar
JaymZz
it is 2002 5.9
Old Aug 25, 2007 | 12:53 PM
Kensai's Avatar
Kensai
Chances are your Tranny is toast! I am in your same situation and just got my replacement tranny in! All started when I pulled into the parking garage, put it in reverse, and nothing, won't move. I can hear the gear going to place, when put in reverse, I can hear my tranmission going to gear, but nothing, seem like in neutral. took it to dealer and when they dropped the pan, saw some parts lying on the pan. All forward gears are working tho.
Go to my thread where I started this as I know you will need a replacement tranny unless it is still under warranty. If it is not under warranty, I would advise you to buy a replacement tranny from http://www.thefastman.com . Their trannys are built like a brick and possibly will outlast the life of the Durango. Much Much cheaper than dealer too!
https://dodgeforum.com/m_911489/tm.htm
Tranny's are 1st Gen Durango's weak link. Mine went out and I am sitting on 82k miles.
Old Aug 25, 2007 | 01:16 PM
JaymZz's Avatar
JaymZz
i have to replace my tranny!!! OMG
its only the reverse!
it cannot be fixed or somthing???
Old Aug 25, 2007 | 01:45 PM
Kensai's Avatar
Kensai
Take it to a dealer or tranny shop to check to confirm. Only way to know.
Old Aug 25, 2007 | 02:52 PM
Mean Green's Avatar
Mean Green
As Ken stated these trannys are garbage. I lost mine at 35k miles. As long as you get a quality built or swap it out for an NV4500 (ram manual tranny) you will be good. If/when my tranny goes again I will be swapping the manual in there and have a nice light tranny that I have full control over.
Old Aug 25, 2007 | 06:32 PM
bigbaddurango's Avatar
bigbaddurango
Dont forget i dought it will help but u might check the t fluid if not $$$$$$ hey mean green what pedals you planing on using? If i build this 408 stroker i will whant a manual so much more fun and to get away from the all time 4 wheel drive as well is it the same length or have to do new drive shafts?
Old Aug 26, 2007 | 01:19 AM
JaymZz's Avatar
JaymZz
i'd rather have the auto tranny... you dont know our country hehe we have the worst traffic... small island alot of cars..
i've just came back from the dealer they will check it out and give me a call later on...
mean green u've lost it on 35,000km!! daamn dodges
is everyone here good with the fastman trannys??? are they worth to buy
