Water in the driver-side footwell
Old 11-09-2008, 09:34 PM
luv951's Avatar
luv951
luv951 is offline
Default Water in the driver-side footwell
Hi guys,
new to the forum and hoping you guys might be able to help me out.
My 2000 Dodge Durango has water leaking into the drivers footwell.
Other cars that I have owned over the years have had minor interior leaks and the cause has always been a clogged drain - like around the sunroof.
On the truck, I could not find any drain lines to try to unclog and did not find any other obvious source.?.?.? Of course, I have never actually seen a leak either.
The leak is only on the drivers side and seems to be almost directly under the pedals...was dry back near the seat.
Any help would be greatly appreciated.
Old 11-09-2008, 09:47 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
Make sure it isn't coolant by smell and touch. Coolant has a sweet smell and a greasy feel to it. If it is it's your heater core. Although I doubt this is your issue as it is usually a leak on the passenger side floorboard. Other than that I'd have to look at my D. Do a search for "clogged drain" or something like that I know it has been an issue in the past.
Old 11-09-2008, 10:01 PM
luv951's Avatar
luv951
luv951 is offline
Definately not coolant. Also, the leaking started as the rain picked up here in OR this fall.
What is my D? A google search for that came up empty. My dodge. com did not have any articles with clog or drain or clogged drain.
Thanks.
Old 11-09-2008, 10:21 PM
andyg's Avatar
andyg
andyg is offline
Originally Posted by luv951
What is my D?
Thanks.
A "D" is slang around here for Durango. All he was saying is that he will take a look at his truck. Also Check the weather stripping around the door for damage or age.
Old 11-09-2008, 10:55 PM
luv951's Avatar
luv951
luv951 is offline
Thanks, that was my second thought, that the weather stripping around the windsheild must be bad.
Tomorrow I will check it again....
any other ideas?
Old 11-09-2008, 11:21 PM
sunnypadreguy's Avatar
sunnypadreguy
sunnypadreguy is offline
a friend of mine had this, his problem was a power cable to some amps, have u checked the grommets on the fire wall?
Old 11-09-2008, 11:33 PM
luv951's Avatar
luv951
luv951 is offline
I have not - good idea. The truck is basically stock, no amps or anything else that is not factory going through the firewall. Any special place I need to look for the grommets, or will it be obvious once I am under the hood?
Old 11-09-2008, 11:34 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
any other ideas?
Could be the seal around your windshield. Did you get a new windshield recently?
Old 11-10-2008, 08:55 AM
deerang's Avatar
deerang
deerang is offline
No special place, gromets on the driver side.. I think there only are 4 or 5 there.. The Gromets are the rubber isolators that insert into the firewall and protect wires from the sharp edges of the firewall, and keep water/dirt/hot or cold air out..
Old 11-10-2008, 09:34 AM
sunnypadreguy
specially look at the one for the steering bar.
Quick Reply: Water in the driver-side footwell
