Which sensor is this?
Old 03-03-2010 | 07:40 PM
Gasnmyveins's Avatar
Gasnmyveins
Default Which sensor is this?
I have a 2001 Durango 5.9 2wd.
I found what appears to be trans fluid in the connector to the sensor that is connected to the bracket with the throttle cable. Driver side, front. Is this likely to be just a bad sensor seal, or was it possibly caused by a fault in the trans itself?
Thanks, Gas.
Old 03-03-2010 | 10:13 PM
master tech's Avatar
master tech
Site Moderator & Tech
Can you take a picture and post it?
Old 03-03-2010 | 10:25 PM
Gasnmyveins
Old 03-03-2010 | 10:36 PM
master tech
Thats a safety neutral switch. They leak at times, when it does replace with a new switch.
Old 03-03-2010 | 11:01 PM
Gasnmyveins
Please tell me it could affect the way my trans shifts. I'm having serious problems with it, and I've been hoping this was the cause. Unfortunately, it doesn't sound like it would be related.
Old 03-03-2010 | 11:08 PM
master tech
Thats for starting and turning the back up lites on. What kind of problems are you having?
Old 03-03-2010 | 11:17 PM
Gasnmyveins
I was afraid of that.
It will shift right the first time. Then it wants to shift into 2nd at around 30 mph. It will not shift out of 2nd into 3rd unless I put it in neutral for 5 seconds or so and then give it enough gas to match rpm. If I don't give it gas, sometimes it will go into 3rd and sometimes it will go back into 2nd for several second, drag my speed down, then shift into 3rd. The 3rd to 4th shift is fine. A lot of the time, it wants to start in 2nd from a light, unless I go into neutral. It will downshift to pass with no problems. It is not slipping. At very light throttle, it will very rarely hunt between 1st and 2nd.
Old 03-03-2010 | 11:55 PM
master tech
Ck the throttle cable adjustment and the fluid level. 1st to 2nd 18 to 22 mph,2nd to 3rd 25 to 30 mph, if 3rd doesn't upshift to 3rd gear until 45 to 50 mph. sorry the seals are hard and will cause this problem.
Old 03-04-2010 | 10:01 AM
Gasnmyveins
Fluid level is good. I checked it per the directions in the manual and it's fine. No burnt smell or discoloration, either.
I have a couple of questions about the throttle cable being out of adjustment. If it's so badly out that the 2-3 shift never happens, would that also preclude the 3-4 shift from happening? As it is, my 3-4 shift has no problems. Also, how do they get out of adjustment to begin with, and do they go from working perfectly to something as bad as this with no intermediate stage? Mine was fine one day, and garbage the next.
Old 03-09-2010 | 06:21 PM
Gasnmyveins
I tried shifting it manually. It is almost normal when I do that. It always makes the 1-2 shift. It makes the 2-3 shift about 7 out of 10 times. It always has made the 3-4 shift with no problems. I don`t know why this should make a difference, but it does.
Quick Reply: Which sensor is this?
