Taking off Emlems on my Durango
Old 03-08-2010, 07:02 PM
tm985's Avatar
tm985
tm985 is offline
Default Taking off Emlems on my Durango
I was just making sure that when I take the emblems off the back/side of my truck that there's no screwholes underneath or anything unsightly. I know there's going to be a little bit of a color difference but that ought to go away after a while.
Thanks guys.
Old 03-08-2010, 07:48 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
nope they just glue on should come off fairly easily, you can use paint thinner to get off the adhesive, just wash and wax it immediately after you are finished
Old 03-09-2010, 07:06 AM
Duranged408's Avatar
Duranged408
Duranged408 is offline
A little heat and a very very very soft plastic scraper usually does the trick. The only emblems that have holes are the V8/V6 badges on the front fender.
Old 03-09-2010, 10:04 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
My 1998 Durango were glue on's.
Old 03-11-2010, 09:35 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
So were mine. I know cause they were off when I bought the D.
Old 03-11-2010, 10:38 AM
Duranged408
Because you had the cheap china made knock off version
Old 03-11-2010, 11:17 PM
hydrashocker
Your right "had".......LOL
Anyway, WD-40 does a great job in removal of adhesives.
Old 03-13-2010, 04:55 PM
KsK9's Avatar
KsK9
KsK9 is offline
You can also use fishing line or dental floss. Start on a corner of the letter and slowly work the line under the adhesive. When finished, use Goo Gone to remove any residue. Then you can compound/polish the area to diminish the paint differences (the paint under the letters/emblem is darker. I do this a lot on BMW's and other cars that want "de-badging".
KsK9
Old 03-14-2010, 07:00 PM
tm985's Avatar
tm985
tm985 is offline
wd-40 is a good idea...and what is the final verdict on the ones on the fender? Cuz I was planning on taking those off as well.
Old 03-14-2010, 09:28 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
The V8 on the fender DOES have a bolt hole. All the others do not.
IndyDurango
Quick Reply: Taking off Emlems on my Durango
