yellowed headlights
Old 03-14-2010, 10:13 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
Default yellowed headlights
more annoying questions from me...lol the headlight lenses are yellowed on the truck and i'm looking for feedback on aftermarket clear/euro style headlights. i'm not interested in the rice rocket look, just want to see if there are any decent clear replacements.
Old 03-14-2010, 11:20 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Most eBays suck. DEPO is a good name brand. You can always clean your stockers if they are not broken.
IndyD
Old 03-14-2010, 11:52 PM
c00nhunterjoe
they are not broken but i have never had luck with the yellowed lenses on any of my ford's. i will give it a try and see what happens. any good places to get the depo lenses? i would like to swap to the clear's and convert to hid
Old 03-15-2010, 01:58 AM
IndyDurango
You actually "sand" the yellow away. Search the 'net for the procedures and products to use.
IndyD
Old 03-15-2010, 05:43 AM
j306's Avatar
j306
j306 is offline
Mothers Mag Wheel polish and a buffer works great.
Go easy though, and take your time.
You just want to slightly blend the lense, not melt it!!!!
You can hand buff too, but the final finish will not look as nice.
Old 03-15-2010, 06:02 AM
KsK9's Avatar
KsK9
KsK9 is offline
Default Headlight Restoration
If you have the tools and products available, it will take some time (I can spend up to 2 hours on BMW headlights). If you don't have access to the equipment, you might be better off with new lenses.
I wet sand with 1500 grit and move to 2500 grit paper, Then, 3M compound and a wool pad on a rotary polisher until the lenses are clear. Follow that with a good polish like Meguiar's DACP or Menzerna and you're done.
Here's an example:
Sanded lenses
Finished with compound
There are some kits available for headlight restoration, but the above equipment does just as good if you have it.
KsK9
Old 03-15-2010, 08:15 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
I do believe walmart has a product for cleaning up your lenses.
Old 03-15-2010, 03:00 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
is there anything walmart doesnt have?
mine are still clear but i wax them everytime i wax the truck, must be just enough protection to keep em clear
Old 03-15-2010, 05:55 PM
Dodge4lyfe's Avatar
Dodge4lyfe
Dodge4lyfe is offline
The UV rays from the sun are what make them yellow..My first Intrepid had one light yellow and one clear as the PO had it parked next to his garage and the one light never saw sunlight while sitting
Old 03-15-2010, 10:14 PM
c00nhunterjoe
i picked up the meguires light restorer, hope to give it a try tomarrow if the rain stays away, i will try to get before and after pics
Quick Reply: yellowed headlights
