help wont start
Old Apr 13, 2010 | 09:47 AM
soupdog06's Avatar
soupdog06
Default help wont start
have a 2001 durango with a 360 ,, wont start now,,smell gas took it to a mechanic and he put in a new crank sensor ,,still wont start,,,have battery power and lots of cranking speed,,help
Old Apr 13, 2010 | 02:05 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is the coil firing(pull a plug and hold it to the block while cranking)? how is the fuel pressure? and how about any more info on the problem, anything could be helpful
Old Apr 13, 2010 | 04:13 PM
soupdog06's Avatar
soupdog06
well it did it before, wouldn't start and went over one day and tried it and started right up, but chek engine lite was on, shoulda had it checked then but didn't ,,ran just fine till now,,,can hear fuel pump come 0n when i turn key on so know its not pump,,,no spark
Old Apr 13, 2010 | 07:49 PM
shrpshtr325
THE ULTI-MOD
make sure you have enough fuel pressure, just because the pump comes on does not mean it is putting out enough pressure have it checked
Old Apr 13, 2010 | 10:00 PM
hydrashocker's Avatar
hydrashocker
Also check for spark!
Old Apr 13, 2010 | 10:39 PM
shrpshtr325
THE ULTI-MOD
the alcohol slowing your reflexes? or just screwing with your cognition??? i said that already
Old Apr 14, 2010 | 11:33 PM
hydrashocker
No, just backin ya up on it.
Old Apr 14, 2010 | 11:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
What was the code for ck engine lite? A bad temp sensor will give you a hard or no start problem too.
Old Apr 15, 2010 | 09:24 AM
soupdog06's Avatar
soupdog06
can i chek those codes with it disabled like it is?
Old Apr 15, 2010 | 10:18 AM
shrpshtr325
THE ULTI-MOD
yea just do the keydance trick
https://dodgeforum.com/forum/1st-gen...ine-light.html
