Electric Fan Shroud
Old 06-15-2010, 02:28 PM
vox87's Avatar
vox87
vox87 is offline
Default Electric Fan Shroud
Appears my electric fan has died. Purchased a universal fan from Car Quest, but didn't think to check the mountings on the stock.
Of course the shroud is all different on the stock, <@> , something like that. Two bolts holding it in place on the left and right.
Is it possible to remove the shroud from the stock fan? Or try to mount the universal fan with its shroud?
Dealer wanted something like $310 for the replacement assembly (fan and shroud). Any recommended places online to purchase from? Or are there any other write ups on a better solution to replacing the e-fan?
Need to get this sucker replaced because it sucks while idling. AC starts blowing warm air and its just too damn hot to deal with that...
Old 06-15-2010, 05:31 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
anything is possible if you put enough effort into it, not sure wher eyou are located, but if you are near by id be willing to give you a hand
Old 06-15-2010, 11:50 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
You can get them at your local auto parts stores for a LOT cheaper.
Old 06-16-2010, 01:43 PM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
I don't know if your 2002 is like my 2001, but here's a writeup on how I removed and reinstalled the shroud after I installed a new e-fan. HTH.
https://dodgeforum.com/forum/1st-gen...-colors-7.html
Old 06-16-2010, 03:54 PM
vox87's Avatar
vox87
vox87 is offline
Thanks... that write up will work.
As for going to the local stores for the fan... ya, I went to them all and they all had the same universal fan: http://shop.advanceautoparts.com/web..._A|GRP2070____
They did look up the part, but it was funny that none of them could really guarantee it was the OEM part. They were afraid it would be another universal fan.
But, I did find a site with an OEM reference: http://www.autopart.com/partsout/200...ANGO/10638.htm
With knowing the actual OEM number, I've been able to find it way cheaper online.
I'll follow up after I replace it. Thanks.
Old 06-17-2010, 10:48 AM
Dans01Durango
NP, please keep us updated on how you did.
Old 06-24-2010, 10:29 AM
vox87's Avatar
vox87
vox87 is offline
Well I'm trying to get the fan out. Like the write up, my A frame blocks a bolt (the side with two). However, on the other side of the fan, i can't get the single bolt out. It turns with both a socket (and allen), but I'm afraid the nut clip is busted or something.
I'm not sure how in the hell I'm going to get anything down there to help isolate the clip it screws into. I've tried jamming a flathead in between the shroud and the mounting to make it taunt, but no luck.
Any ideas?
Old 06-24-2010, 11:55 AM
vox87's Avatar
vox87
vox87 is offline
Well I broke the shroud part around the bolt. Removed the fan and I can now get my hands down in there. I can feel the plastic clip turning around inside the molding. Going to see, if I can get a small pair of vice grips up in there to wedge the clip.
Typical DIY...lol. Could have been done 2hrs ago.
Old 06-24-2010, 12:59 PM
Dans01Durango
I forgot to mention that part, the plastic got broke as well. Used a small pair of vice grips to hold it in place before removal. Busted knuckle and blood was shed. Fun night!
Old 06-24-2010, 01:47 PM
shrpshtr325
THE ULTI-MOD
but the beer will help you to forget that part
Quick Reply: Electric Fan Shroud
