Old Aug 6, 2015, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Common A/C issues: problems and solutions
Old Oct 20, 2013 | 06:30 PM
  #181
that_guy's Avatar
that_guy
Your blend door might also be sticking towards the cold position too.
Old Oct 23, 2013 | 11:14 PM
  #182
ole silver 03's Avatar
ole silver 03
Originally Posted by R1speedkills
I just create an account to try and diagnose my "Fog Horn" AC. While at highway speed this does not happen. Just after stopping and while stopped, a "Fog Horn" Type noise emits from in dash. I read that the system might be over charged. I just had the AC serviced at a shop in Olympia. I took it to them because it was not making cold air. I also took it to them because they put on a new AC clutch last summer. Any ideas what might create the "Fog Horn" sound??
THX
this might sound stupid , but replace your thermostat on your motor...this should fix the fog horn sound....been their and done that....good luck.
Old Oct 30, 2013 | 08:27 AM
  #183
drbdxb's Avatar
drbdxb
In the words at the top of the page you mention about the fan clutch. I have fitted two large electric fans blowing onto the engine from the front of the radiator to overcome the other standard Durango Mk 1 problem, overheating in high temperatures.
Would that negate the clutch issue.
Old Mar 4, 2014 | 09:06 AM
  #184
cj5orion's Avatar
cj5orion
Default 10 amp ac fuse blows ?
havent seen anyone with this problem yet.
needed some ac the other day...jus normal air blowing through ?
took her into the shop,had the freon evac'd,replaced with new.
still no cold air ?
10 amp fuse keeps blowing
no recent elec work on the truck
besides gettin out the voltmeter and fumbling around all day...
could somebody give me a idea what/where to look ?
much...very much... appreciated
Old Mar 4, 2014 | 02:11 PM
  #185
that_guy's Avatar
that_guy
Check if the clutch is engaging on the compressor. You'll see what looks like the center of the pulley turning with the belt if it is. My guess would be that it isn't and the solenoid that engages the clutch (or the wires going to it) are shorted and blowing the fuse. It could possibly be a sensor too.
Old Mar 5, 2014 | 07:57 AM
  #186
cj5orion's Avatar
cj5orion
yea,clutch is not engaging.
gonna try "direct to batt test" se if I can isolate/pinpoint
expensive repairs/replacement here in "kalifornia"
Old Apr 25, 2014 | 10:43 PM
  #187
Ratelo's Avatar
Ratelo
I had to put a bit of Freon into my system but apparently I put too much in, O gathered that from reading the posts here. The blow off from the condenser is that toxic? can I just run it until the blow off stop or will it ruin my system. I do not have the $ right now to get it fixed so is there any more options for letting some of the pressure out?
Old May 18, 2014 | 10:47 AM
  #188
amps1956's Avatar
amps1956
looking for most common source of leaks 1998 ram 1500 Thanks
Old May 18, 2014 | 10:56 AM
  #189
that_guy's Avatar
that_guy
I had the seal where the lines bolt onto the top of the compressor go bad on me.
Old Jun 6, 2014 | 07:13 PM
  #190
volaredon's Avatar
volaredon
huh where is the post that I put in here?
