Something weird with tranny
Old Feb 14, 2011 | 09:48 PM
Ja2000's Avatar
Ja2000
Default Something weird with tranny
Hey guys I am new to the site and I have looked around but could nit find a answer to my question I checked the fluid in 1999 durango and it looked and smelt burnt now I know that plus 4 can have a diffrent color and smell and be fine but it was bad so I changed fluid and filter and I am still having the same problem the problem is is that once you drive for a while and the tranny warms up good and you come to a stop once you go to mive again its very sluggish there are no noisies or hard shifting and once you get going its fine any advice would be great thanks guys
Old Feb 14, 2011 | 10:01 PM
samnbensdad's Avatar
samnbensdad
Are you certain it's related to your transmission? Do your RPMs increase during this sluggish time? Probable need more details.
When was the last time you cleaned the TB, changed plugs, wires, cap/rotor, air filter...?
Old Feb 14, 2011 | 10:13 PM
Ja2000's Avatar
Ja2000
It was done recently the rpms dont increse you can hold it steady at say 2000rpm and it will saty there and slowly start to move and like I said omce you get going it becomes fine
Old Feb 14, 2011 | 10:22 PM
WhiteWidow00's Avatar
WhiteWidow00
Did you try moving the gear selector to "1" to make sure its in the lowest gear? Also pay attention to the sounds and RPM to see if it's upshifting when you drive from a dead stop (it should upshift around 15 mph). When you replaced the fluid, you did a replacement and not just a flush, correct?
Edit: Just re-read it and just noticed again you did a fluid/filter change so disregard my last question.
Old Feb 14, 2011 | 10:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
When you replace the filter, did you also adjust the front and rear bands? You could also have a sticking governor sensor, and starting in 2nd or 3rd gear like whitewidow00 had said.
Old Feb 14, 2011 | 11:55 PM
hydrashocker's Avatar
hydrashocker
+1 Widow
Ensure that you are actually in 1st gear and not stuck in 2nd or 3rd.
Old Feb 15, 2011 | 12:03 AM
Ja2000's Avatar
Ja2000
Any write ups on how to check and or adjust the bands?
Old Feb 15, 2011 | 12:30 AM
WhiteWidow00
Why yes there is! But first which engine do you have because there's 2 transmissions...
If you have a 5.2L:
https://dodgeforum.com/forum/1st-gen...ment-44re.html
If you have a 5.9L:
Size:  252.0 KBName:  photo-39.png
