She overheated, again!
Old Aug 11, 2011 | 04:30 PM
  #131
adukart's Avatar
adukart
From 2000 on up the durangos have electric assist fan don't they, so is it you have a bad connection and the fan shuts off? just a thought
Old Aug 11, 2011 | 11:01 PM
  #132
ajoshi91's Avatar
ajoshi91
Its possible. Though what about my original concern of air in the cooling system? I dont think i have multiple problems you know? idk its tough to figure out. I need more experienced hands looking. i'm not sure what i'm looking for exactly you know?
Old Aug 11, 2011 | 11:37 PM
  #133
adukart's Avatar
adukart
I get what you're saying. Though I'm not convinced that you had air in your system. Do you know how long your reservoir was dry or a rough estimate. If you had air getting into your system wouldn't you have lost coolant in the radiator also? This is a unique situation it seems like.
Old Aug 12, 2011 | 01:22 AM
  #134
ajoshi91's Avatar
ajoshi91
Its weird. Though i may not be assessing the problem properly. And The reservoir was dry for maybe a day or two? maybe not even that.
I mean coolant is coming out of the bleeder valve when I'm burping the cooling system right? Maybe thats why my reservoir went dry. Burping the system multiple times caused it too lose too much coolant?
I'm gonna post a video of my bleeder valve as I'm using it with the heat on and the engine up to full temp and the car on than you can see what i consider air coming out of the bleeder valve. But basically its opened a couple threads and bubbles are coming out than just coolant than again it bubbles quite a bit and this process goes back and forth a couple times.
Old Aug 12, 2011 | 10:52 AM
  #135
adukart's Avatar
adukart
When I burped mine it was 20 degrees so I drove 15 miles with my cap on but not sealed and there was no air in my system. I wasn't aware there was a bleeder valve.
Old Aug 12, 2011 | 12:03 PM
  #136
ajoshi91's Avatar
ajoshi91
well on the 4.7l its like 6 inches past the rad cap on the upper rad hose. the bleeder "plug" on mine takes an Allen wrench/hex wrench. and you undue it a couple threads. yours would be in a similar location .
I work 12-8 today and its 11 now so I'll post the video of my bleeder valve in action when i get home.
Not the best picture since its so up close but this is my bleeder valve and you can kinda see bubbles coming out. I took this with my phone soo yeah you know not to good.
Old Aug 12, 2011 | 03:05 PM
  #137
srch4me's Avatar
srch4me
the bleeder valve is a new thing... we dont have them on your 98 durangos
Old Aug 12, 2011 | 04:39 PM
  #138
adukart's Avatar
adukart
Ok that would be why I never saw one.
Old Aug 12, 2011 | 10:39 PM
  #139
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the bleeder valve is only on the 4.7l engines, the 5.2 and 5.9s dont have one
Old Aug 13, 2011 | 02:12 AM
  #140
Biff85ta's Avatar
Biff85ta
The same process that allows the radiator to draw coolant from the reservior will allow it to draw air if it gets too low. Do not let the level get low in the reservoir. It may take a couple of tries to get everything full. You need to be checking things daily to make sure it is not getting low.
