She overheated, again!
+1 hydra. lol I'm most likely gonna take it to a shop for diagnostics if i cant find any leak or problems.
I'll get back to you guys if i find something interesting. Until than lets agree with hydra and give this thread a little rest lol
Real quick thought. Go to autozone and do the loan a tool on a cooling system pressure tester. See if it will hold pressure. It will also allow you to check for leaks with the system and the motor cool. If all else fails buy the dye kit and a black light.
The pressure tester you're talking about is it where you use the testers cap to replace the radiator cap and than as the engine warms see how the pressure acts?
I've done this test. I pumped the tester up to 20 psi roughly and once it got up to temp it slowly built pressure in the cooling system as i was told it should? So the pressure test on the cooling system came out normal.
I did this test when i did the hydrocarbon test. about a month ago maybe?
