DIY: Adding a overhead console w/ temperature and compass (Durango Edition)
THANK YOU SO MUCH!!! i owe you a beer if or when we ever meet.....
I had a delema where the factory harness connected under the dash... i was told that it connected into a white connector with a cap on it and i was also told that i went into the C3 plug of the junction box... that diagram conforms that its the C3 plug..... i have it noted and i will change it in my write-up..
again, THANK YOU
BTW: Thanks to everyone for the positive comments on the thread.... it is that and the fact that someday i will have helped someone do something they didn't think was possible that brings me joy and makes doing this and any write-up so much more enjoyable and worth while....
I also forgot to mention that the factory harness for the overhead console also includes a plug for the Auto-Dim rearview mirror. I did not switch mine (yet) because it was already riped from the donor truck i got the console out of..
For some reason the local yards here do not get to many dodges in ... esp. the durango's wonder why??..... lol
I've thought about doing this on mine, as I'd like to be able to have the trip computer and the compartment. If I do feel ambitious enough this thread will definitely be a big help.
Based on the number of these things out there I'd say a lot of them are still on the road. lol I still am amazed by how many I see!
UPDATE:
Since I'm an engineer I figured I'd grab my voltmeter and go check the pins to see if they were working. All I had to do was hook up a ground (I'd used the dome light ground for the computer) then everything was good to go.
btw great write up Old School
I have a 99 dakota, its got the crappy overhead console with the clip instead of temp sensor. Would I need to do any cutting of the headliner (hoping no but might not mind since excuse to pull it and get it redone) since I already have the console and just need to wire up the computer up top?
Also JW what does the overhead display besides temp? My moms 00 durango displays like fuel mileage and other stuff and a compass.
And last question what was the total cost? Im 17 soo im on a budget but Im the only one in the family with a dodge without the overhead console that has the temp and stuff and I feel left out.
IIRC, if you have the overhead already then the wires should already be there but, don't hold me to it. That make it easy because the it just be plug and play.
The whole cost for the project was about $10 bucks... the you pull it yard charged me $5 for the console and another $5 or so in misc connectors.
