headlights are STILL flashing
Old Jul 19, 2013 | 12:09 PM
  #31
that_guy's Avatar
that_guy
I'm pretty sure I only have 1 fog light relay too.
Old Jul 28, 2013 | 12:34 PM
  #32
hemi_newman's Avatar
hemi_newman
Update...now my radio is turning on and off...it turns off than back on and repeats i lose the radio and the clock..than it will stay on for a while and start doing it again.I have the factory radio.
Old Jul 29, 2013 | 10:03 PM
  #33
that_guy's Avatar
that_guy
It really sounds like a power issue to me.
Old Jul 29, 2013 | 11:33 PM
  #34
master tech's Avatar
master tech
Site Moderator & Tech
Do this, Remove both kick panels and look for a ground wire and tighten. If that doesn't fix the problem. Get a Central Timing Module from the dealer and have it program. Do not use one from junk yard. Because you don't know if that vehicle had the same problem.
Old Jul 30, 2013 | 05:17 PM
  #35
hemi_newman
What are kick panels?Im taking the truck to the dodge dealer and there going to hook it up to some fancy computer and do some tests.$95 what a rip off!All they do is plug it in,push some buttons and read what it says.Sorry that is alot of money for what 20mins of there time.
Old Jul 30, 2013 | 05:55 PM
  #36
that_guy's Avatar
that_guy
The kick panels are the plastic panels on the sides of the footwell.
Old Aug 1, 2013 | 12:00 AM
  #37
master tech
Hemi Newman
The more time you spend with the members of dodge forum, The better you will be with your vehicle. Always ask questions, that how we all learn. You do have a lot of dodge techs on the forum and just like all the other members, they will help.
Old Aug 1, 2013 | 06:14 PM
  #38
hemi_newman
Ok thanks guys..I just dont have the $400 for a new CTM right now.
Old Aug 1, 2013 | 06:19 PM
  #39
that_guy's Avatar
that_guy
As a temporary fix you could run new wires to the headlights and put a new switch inside the truck.
Old Aug 2, 2013 | 01:22 PM
  #40
Kensai's Avatar
Kensai
With the radio/clock also going out, I would have to fault the CTM as MasterTech says. Get a new replacement to see if that works.
