Water Pump Bolts...breaking?
Hello all,
I'm in the middle of a water pump change due to the pump starting to dump anitfreeze all over the place. My car is a '01 Durango, 5.9 R/T 4x4.
I'm at the point in the process where I'm unbolting the water pump. Half of the bolts loosened nicely when broke loose. Others are VERY tight, so much so I'm thinking the bolts might be breaking instead of loosening.
Is there any history of these bolts breaking in the block? I've read about intake manifold and exhaust manifold and thermostat housing bolts but nothing here about water pump bolts. I guess anything is possible.
I've broken them loose, sprayed them with PB Blaster, move them slightly back and forth, resprayed them, then let them set overnight. I'm planning on spraying them again tonight, rocking them back and forth again then let them sit overnight again before I attempt their full removal.
Anybody have any tricks on removing these before I try again? Are these bolts prone to breaking or am I just being paranoid? Yeah, I'm worried about it, can you tell??
This is my first major repair on this car and it has gone smoothly until now.
I DON'T want to break the bolts off! They just feel 'weird' to me and too tight, not loosening up properly...
TIA
Tom
TIA
Tom
Thx for the reply.
Worked on it last night and was able to pull all of the bolts out with none of them breaking!
So it's all down hill from here on out reassembling everything.
I found it interesting / disconcerting that a couple of the bolt holes let antifreeze out when I pulled them so they must go into the water jacket. So I guess I'll need to seal those threads with something when I reinstall....?
Thanks
Tom
![Icon Headbang](https://dodgeforum.com/forum/images/smilies/icon_headbang.gif)
Thanks
Tom
Thx for the reply.
Thanks
Tom
Thanks
Tom
Yep, and be sure to clean the bolts with a wire wheel before you put everything back together. It'll be an easier reassembly, better seal and if you have to go in again, easier disassembly. I generally like to use #2 seal-a-gasket on bolt sealing, if it's even made anymore.
Well, he might be like a young woman who marries an elderly man. Very patient.
![Icon Wub](https://dodgeforum.com/forum/images/smilies/icon_wub.gif)
Trending Topics
