Hitting Rev limiter
Old 08-03-2018, 12:24 AM
Nick-'s Avatar
Nick-
Nick- is offline
Default Hitting Rev limiter
So I have a ‘03 Durango 4.7 L and it has been hitting a rev limiter while in every gear. It gets to 3,500 RPMS and hits it. Plus, it will randomly shut off going down the road. Plus, it has an incredibly hard time taking off. It feels bogged down and the RPMS increase very slowly. Any ideas of the problem? I replaced my ECM module for a brand new one, pre-programmed to fit my specific Durango. Still having the issue though.
Old 08-03-2018, 06:20 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
sounds like your in limp mode, should be a check engine light for that, hook up a scanner and see what it says.
Old 08-04-2018, 12:05 AM
Nick-'s Avatar
Nick-
Nick- is offline
Sounds like a plan, thanks
Old 08-11-2018, 12:44 PM
Jason Marshall's Avatar
Jason Marshall
Jason Marshall is offline
had the same thing happen a while back after changing a coil pack that was bad. Ended up being a bad connection in the harness going to the coil pack..
Old 08-11-2018, 08:17 PM
Nick-'s Avatar
Nick-
Nick- is offline
I figured out what it was. It was the crankshaft position sensor. Thanks guys
Old 09-04-2018, 08:42 PM
Jason Marshall
what brand crank sensor did you use so far the three I have used don't work
Old 09-04-2018, 09:04 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
OEM Mopar part. Our trucks don't generally care for the aftermarket fellers.
Old 09-05-2018, 12:07 AM
Nick-'s Avatar
Nick-
Nick- is offline
He is correct, it’s OEM Mopar. Bought from advance auto parts
Old 09-05-2018, 08:12 AM
HeyYou is offline
Advance sells OEM mopar? That's new.
Old 09-06-2018, 10:33 AM
Jason Marshall
NAPA sells OEM picked one up last night for $39.99 part # ECH CSS620
Quick Reply: Hitting Rev limiter
