Major overhaul.
Old 05-22-2019, 12:36 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
Originally Posted by b1lk1
I leave my Durango sitting outside in the moisture unused for weeks at a time. Never had any froth or water inside.
Water gets in the oil from condensation every time you start a cold engine. Think of a cold block with hot combustion chambers... like cold water sitting in a glass. The water evaporates when your engine gets hot enough. This is why folks who mostly do quick trips, should change their oil on a shorter schedule. If you're constantly doing five minute trips around town, the water starts accumulating. This is why I was never a fan of putting in colder thermostats, especially those with a 4.7L. Also why I don't run conventional oil... it tends to coagulate and create sludge, unlike full syn.
Old 06-02-2019, 11:27 PM
Joseph McAuley's Avatar
Joseph McAuley
Joseph McAuley is offline
Originally Posted by sporta
Side question regarding the steering/suspension upgrade. Looks like I am having to replace the bushings on my power rack on my 2000 4.7l Durango. Did you replace the power rack and pinion and if so was it possible to drop it out prior to completely disassembling the front end? Going to have to try and replace it one side at a time if possible...thanks in advance. And I will be digging in the forums prior to starting...need to clear working space and get that damn 5.9 2000 D out of the driveway
Steve
steve, I did it in my garage with a jack and two jack-stands. The taller the better. I had to disconnect the sway bar, pretty simple, just 4 bolts I think.
I had had to replace the steering rack because I still had clicking noise and slop even with new bushings. I think I found it for $80 refurbished on amazon.
If you’re going that far I suggest doing sway bar bushings, I used pro-thane I think. I like polyurethane bushings but rubber works fine.
Let me know if you have more questions!
Old 06-02-2019, 11:28 PM
Joseph McAuley
Came from the coolant system. Meaning a head gasket blew at a minimum.
Old 06-02-2019, 11:41 PM
Joseph McAuley
Sounds like an awesome project. Would love to see pictures of the finished project
Well, it’s running! I’ve driven it 2 miles so far :P
here are some progress pics towards the end. More to come!
Fuel/ignition done, just air/water left!
Air/water done, now to chase gremlins
Just a few hours of locating plugs, I forgot to plug in the oil pressure switch, fuel vent solenoid, and crank position sensor and it fired up! Let it idle an hour and burped the coolant. Took her for a spin and topped everything off. Now to get it registered and inspected (Maryland, ugh ):
Old 06-02-2019, 11:44 PM
Joseph McAuley
Originally Posted by JeeperDon
Seems odd that all that needed replacing. I'm at 125,000 miles and only replaced the steering rack in your list. I did have to do the trans though back at 95,000 miles.
Youre right, although I had 100,000 more miles than you did. Also this truck was used for off-roading very frequently, so bushings, bearings, joints and suspension should wear faster. The engine could have been overhauled but I expected that to take longer than replacing it.
Old 06-02-2019, 11:46 PM
Joseph McAuley
Originally Posted by car5car
Oil gets water in it, if engine is not warmed up well. Maybe your engine is OK. Anyway you have to diagnose problem first, repair later. Compression test, wet compression test, check spark plugs, check codes. Act smart, get service manual.
Usually people don't repair cars for fun.
Was probably a blown head gasket. I didn’t know if the head gasket had been blown long enough for the head to have deformed, and if I were to replace the head I would have spent more time fully overhauling the whole thing. For me it was faster to replace the engine than to rebuild it. I realize most people would rather be more frugal, but I couldn’t have the truck down for that long, and I actually enjoy working on it and learning. So does my friend who helped me most days.
Old 06-02-2019, 11:49 PM
Joseph McAuley
Yeah I’ve been running royal purple for a few oil changes, and my trips are all over 15 minutes. This new engine is being broken in with royal purple AND Lucas break-in additive. I will change it after 500 miles and inspect the filter, possibly send a sample for analysis.
I have heard synthetic isnt isn’t recommended for break-in but with the additive I feel ok doing it because then the engine will have only ever seen royal purple, and I don’t need to worry as much about compatibility or contamination.
Old 06-06-2019, 10:13 AM
Swat455's Avatar
Swat455
Swat455 is offline
Especially when you pull the head off and this is the view you see....:Rebuild of replacement should begin tonight or tomorrow weather permitting...
This is dodges new cylinder deactivation motor...
Old 06-06-2019, 02:02 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,226 Likes on 2,976 Posts
Yeah, but, it only works once, and can't reactivate the cylinder.
Old 06-06-2019, 02:14 PM
sporta's Avatar
sporta
sporta is offline
I thought it was the hidden cash for clunkers mechanism or how to get rid of first gen Durangos lol
Quick Reply: Major overhaul.
