Hard start 5.9
Old 09-27-2020, 09:49 AM
Vega419's Avatar
Vega419
Vega419 is offline
Default Hard start 5.9
I own a 2001 with the 5.9,currently have 88,xxx miles it has a hard start every day for a while now,I ran into a guy yesterday and he asked me if I ever get hard starts I said that's funny you say that it happens everyday,he said he owned a durango and he installed a high volume oil pump and it fixed it, has anyone put a high volume oil pump to resolve the hard starts?? The hard starts has been bugging me and I can't find the issue.
Old 09-27-2020, 02:44 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,335 Likes on 3,077 Posts
Oil pump doesn't have anything at all to do with the engine starting.
Does it turn over nice, just not fire? Or does it crank slow?
Old 09-27-2020, 04:42 PM
Vega419's Avatar
Vega419
Vega419 is offline
Old 09-27-2020, 04:43 PM
Vega419's Avatar
Vega419
Vega419 is offline
I can't upload a video so I put a link to my fb so you can see the video.
Old 09-27-2020, 04:59 PM
HeyYou is offline
It shows as a private group, and wants me to log in, which is problematic, as I don't have a facebook account. (nor do I want one......) Upload to Youtube?
Old 09-27-2020, 06:03 PM
Vega419's Avatar
Vega419
Vega419 is offline
Default https://youtu.be/XxLLdR8o5wc
here you go thank you
Old 09-27-2020, 09:07 PM
HeyYou is offline
The couple clicks when you first turn the key would make me nervous...... (if that is actually the starter motor clicking)
Try cycling the key a couple times on the next cold start. Don't crank it, just let the fuel pump run till it shuts off, do it a couple more times, see if it starts any easier.
Old 09-27-2020, 11:22 PM
Vega419's Avatar
Vega419
Vega419 is offline
That is indeed the starter you're hearing and I've tried several time priming the fuel line by turning the key in the one position, doesn't matter i could prime it by turning the key 4 times then try starting it still has a hard start.
Old 09-28-2020, 08:49 AM
HeyYou is offline
It sure cranks nice once the starter actually starts turning the motor at least.....
How are the plugs/wires/cap/rotor? Getting any codes? Pending codes? What spark plugs are in it?
Old 09-28-2020, 10:22 AM
Vega419's Avatar
Vega419
Vega419 is offline
It's due for a tune up and autolite 3923 plugs
Quick Reply: Hard start 5.9
