Why do you want to replace it? PCM controls the trans. Needs to be flashed to the correct VIN for your Durango, else the SRS, and ABS systems whine about it, and are disabled.
No clue if they are disabled. The Durango won't shift into overdrive while driving.
Need to plug in with a scanner, and see what the PCM is seeing. If any of the sensors it relies on to determine shift points is reporting inaccurate data, it won't shift. If it thinks the trans is too hot, it won't shift, and O/D gets disabled before the temp light comes on.....
