surviving through mods
Old May 4, 2007 | 01:25 PM
  #31
das2123's Avatar
das2123
Default RE: surviving through mods
ORIGINAL: brute
ORIGINAL: das2123
So you are saying that a UDP reduces HP? It actually frees up HP, again dyno proven, rather than create HP. The unorthodox pulley is one of the best ones out there also.
Any dyno results on engine life?
On life, no...just people who have had them on their neons for years and thousands and thousands of miles.
The MPx pulley on my older 99 neon has been on there for about 50,000 miles and the engine is still running strong.
Old May 4, 2007 | 01:41 PM
  #32
das2123's Avatar
das2123
ORIGINAL: dysphagia
on higher hp cars such as the srt the UDP's may gain 1-3hp peak but hp is lost in other areas. reducing the area under the curve and engine life is not worth it for a car that 1-3hp really doesnt make a difference on.
I guess I need to alert all the 1st gen turbo neons out there that they are reducing their engine life because they are running a UDP
Old May 4, 2007 | 02:03 PM
  #33
dysphagia's Avatar
dysphagia
its kinda common sense...think about the reason for a harmonic dampner. engineers do not put them on cars for no reason. they are there to lessen the stress on the crank when the various accessories are engaging. UDPs that include a dampner are not such a bad idea, just those that are cheap and eliminate preventative measures put in place by car manufacturers.
Old May 4, 2007 | 02:41 PM
  #34
das2123's Avatar
das2123
True, but not every car/engine is engineered to perfection. For example, the "harmonic balacer" doesn't even balance the the crank on the neon engine. I understand your logic, but thuth be told there are probably a collective millions of miles on NEONS with UDP's with no reported problems.
Again, this is only for neons (which is the forum we are in).
Old May 4, 2007 | 03:33 PM
  #35
dysphagia's Avatar
dysphagia
ORIGINAL: das2123
it may be called a harmonic balancer but it serves no "balancing" purpose. it is a vibration dampener not some sort of balancing device.
Old May 4, 2007 | 03:50 PM
  #36
das2123's Avatar
das2123
ORIGINAL: dysphagia
ORIGINAL: das2123
Technically it isn't a dampener on the neon engine.
ORIGINAL: Michael Volkmann II
IT isn't a dampener[/b]
Old May 4, 2007 | 03:57 PM
  #37
dysphagia's Avatar
dysphagia
if it has a rubber section separating the two parts is a dampener
Old May 4, 2007 | 04:07 PM
  #38
das2123's Avatar
das2123
ORIGINAL: dysphagia
ORIGINAL: PurpleNeon
There's a difference between a harmonic dampener, and an externally balanced engine. The Neon is not externally balanced, if it were the crank pulley/dampener would have to be keyed to keep the balancing it the same place.
UDP's are fine.
ORIGINAL:Punishers Customs
In this case, the neon IS internally balanced and the OEM pully is balanced seperately since it doesn't have a keyway to locate it on the crank. It's just a heavy lump out there on the end of the crank.
I've always wondered why they didn't cast the thing in aluminum rather than iron from the factory.
Regardless, as long as your udp isn't ridiculously out of ballance I wouldn't worry about it.
Old May 4, 2007 | 04:16 PM
  #39
spudsterier's Avatar
spudsterier
i guess that i should just put the stock pulley back on my car then.....i dont wana cause any problems..
though maybe it would help that my crank is balanced using the udp i have
Old May 4, 2007 | 04:17 PM
  #40
QuiK615's Avatar
QuiK615
My opinion is better than your opinion[:'(]...
