stupid crank pulley
Old May 24, 2007 | 03:43 PM
neoncrazy101's Avatar
neoncrazy101
Default stupid crank pulley
alright, i rented a Harmonic Pulley puller from autozone and it worked good until the bolt wouldn't go anymore cause it was too small. the pulley is halfway off. how in the world do u get it off the rest? or did Autozone give me the wrong one?
Old May 24, 2007 | 04:24 PM
spudsterier's Avatar
spudsterier
Default RE: stupid crank pulley
there should be 2 or 3 push rods that go along with the pulley....you need the longest one
if they only gave you one, then sumone probally kept the ones that you need when they rented it previously....
you could try to get 2 prybars behind the pulley...1 on each side...and just work the pulley the rest of the way of
Old May 24, 2007 | 04:26 PM
neoncrazy101
i used the longer one. guess i better go find my crowbars.
Old May 24, 2007 | 04:27 PM
03neonRT's Avatar
03neonRT
ORIGINAL: spudsterier
Just be careful not to damage the outer timing cover...I've also heard of people heating up the pulley while it was on the crank with a butane torch.
Old May 24, 2007 | 04:30 PM
spudsterier
i heated up the pulley real good the first time i ever took it off...ended up melting the timing cover a bit[&:]
if you got it half way off with the longer rod, then you might be able to work it off with your hands....
the logest rod i have for my puller lets me take the pulley completely off with some room to spare
Old May 24, 2007 | 07:44 PM
neoncrazy101
i've tried by hand but its on there good. I dont think this Neon has ever been worked on cause everything has been a pain the butt to take off.
Old May 24, 2007 | 09:05 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Mine was the same way, luckely I had a pushrod sitting around from a 350, it was the same diameter but longer, just head over to the hardware store and get like a 3/16 rod (I think that is the right size), and cut it to lenth.Will work like a charm
Old May 24, 2007 | 11:31 PM
das2123's Avatar
das2123
Passenger side motor mount bolt works good.
Old May 26, 2007 | 03:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
Miller tools has the special tools needed to remove the the pulley. There are puller 1026 and pin that into the crankshaft bolt hole 6827-A.
Old Jun 5, 2007 | 07:19 PM
mathias's Avatar
mathias
You've hopefully gotten this off already, but if not or someone else needing the info, try this.
Three jawing using the crank bolt will get you almost 3/4 of the way off, after that, remove the bolt and slide a 1/4 socket extension (like a six inch one) into the crank bolt hole. The end of the extentsion sets nicely in the bottom of the crack hole and is too small to damage your threads. Your three jaw center bolt will also seat nicely into the receiving female end of the extension. A few turns on on the puller and she'll slide off easily.
hope this helps someone!
