engine block problems
Old 09-15-2007, 11:48 PM
Girlski's Avatar
Girlski
Girlski is offline
Default engine block problems
Hello, I"m new the to forum but not new to cars, right now im driving a first gen dodge neon sport dohc, and im trying to find an engine block to rebuild for it to make it high performance, and im trying to diside wheater to stay with the neon engine, or go with an eagle talon, or a first gen eclipse.
any suggestions?
Old 09-16-2007, 02:03 AM
12 volt's Avatar
12 volt
12 volt is offline
Default RE: engine block problems
srt 4 swap is probably the best engine you can somewhat easily get into these cars
Old 09-16-2007, 05:28 AM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
Personally with all the hassle involved in getting an SRT engine and making it fit perfect I'd say your better off buying an SRT Turbo and putting iton your Current DOHC engine.rather than swapping out and getting the computer and electronics to work. The DOHC will make just as much power as the SRT-4 Engine withthe SRT-4'sTurbo for a whole lot less hassle and money.
Old 09-16-2007, 05:44 AM
HabitatHxC's Avatar
HabitatHxC
HabitatHxC is offline
if everyoneisjumping off a bridge would you?
Old 09-16-2007, 06:07 AM
Slashwannabe
ORIGINAL: HabitatHxC
Yes I probably would.
Old 09-16-2007, 08:02 AM
rtneon67's Avatar
rtneon67
rtneon67 is offline
you could swap in a 2.4 from a stratus. use srt internals and turbo. i know i guy running 11's on the setup with 19 pounds of bosst.
Old 09-16-2007, 09:09 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
The eagle talon motor and eclipse motor will not work, the head is "backwards", meaning the intake manifold is on the back of the motor and the exhaust manifold is on the front. If you want to build something up, either stick with your current motor or get a 2.4 liter out of a stratus or pt cruiser.
Old 09-16-2007, 09:59 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
i say just stick with the neon motor
Old 09-16-2007, 01:36 PM
Girlski's Avatar
Girlski
Girlski is offline
well see now i would put a turbo on it, but my engine has 150,000 miles on it, and with that many miles on it, i wouldnt want to put a turbo on it, i dont want to put an srt-4 engine in it because like he has that it would be too much of a hastle and stuff, i'd rather mess with the electronics and everything since i already took out the A,C. i dont have power windows and all have really for elec. is dashboard cd player, speakers and normal headlights and tail lights. the rest of the little things that go with the engine arent a big deal, i already had to put new harness's everywhere from when it blew a head gasket on the origonal gasket that it had when i bought it.
Old 09-16-2007, 03:26 PM
96ACR*'s Avatar
96ACR*
96ACR* is offline
I would go with a 2.4 out of a stratus or something and just build it up. Oh and for turbo's you can take a look at this website.. it has a lot of good information and a lot of options turbo wise www.hahnracecraft.com
Quick Reply: engine block problems
