Brakes
Old 01-06-2005, 10:58 PM
neonman1996's Avatar
neonman1996
neonman1996 is offline
Default Brakes
I was wondering is there a problem with my brake in the front i did change the rotor and brakes and petal go's almost to the floor I TOOK THE CAR IN TO DOUBLE and was told there is nothing wrong but my brake petal is almost on the floor why is this THANKS ALOT
Old 01-06-2005, 11:00 PM
savage_RT's Avatar
savage_RT
savage_RT is offline
Default RE: Brakes
air in tha lines?low on brake fluid in tha reserver?
Old 01-07-2005, 12:56 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Cr@zy Squ33 is offline
Default RE: Brakes
Did you only do one side of the car? If so therein lies your problem. Time to redo both sides now.
But yes, air in the lines could cause it but its more than likely that you only did one side of the car.
If you did do both sides try pumping the brakes a few times.
Old 01-07-2005, 01:03 AM
neonman1996
Default RE: Brakes
I did to all that and it is still very soft i tried everything i put new rotor's brakes on the car do you think the calibers are bad ???
Old 01-07-2005, 01:05 AM
neonman1996
Default RE: Brakes
Sorry but i am new to all this so sorry if i mess any thing up not sure on how to reply so bare with me please thanks
Old 01-07-2005, 01:06 AM
neonman1996
Default RE: Brakes
I did do both sides of the car so i really dont know what is going on
Old 01-07-2005, 01:15 AM
Cr@zy Squ33
Default RE: Brakes
I don't think tha calipers are bad. It could be low fluid or something. I still think you should try to pump the brakes and see if that stifens the pedal up a bit. I wouldn't really drive it until lyou figure out what the problem is.
Old 01-07-2005, 01:30 AM
neonman1996
Default RE: Brakes
I am getting great flow out of both calipers the pedle is still soft and almost to the floor
Old 01-07-2005, 03:45 AM
ewetho's Avatar
ewetho
ewetho is offline
Default RE: Brakes
Are you bleading the back brakes too?
Old 01-08-2005, 02:03 AM
neonman1996
Default RE: Brakes
I have done everything maybe the booster is going bad wll that make more sence???
Quick Reply: Brakes
