finally race the Crx check it out
Old 05-26-2008, 02:04 PM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
Default finally race the Crx check it out
ok so the first race seemed to go ok.. but im not sure if im suppose to red line it in each gear while racing. so i dont know and then the second race i shifted into 3rd to quickly and then at the end i shifted into 4th socheck it out
well here it is
1st race
http://www.youtube.com/v/v-iDG_hX1os
2nd race
http://www.youtube.com/v/TTKIeP1K1z4
Old 05-26-2008, 05:59 PM
JackMehoffer69's Avatar
JackMehoffer69
JackMehoffer69 is offline
Default RE: finally race the Crx check it out
ORIGINAL: boxerjl2
well here it is
1st race
2nd race
LOL, you puss. This is specifically why people should not recomend MTX transmissions to everyone. They only help when you know how to shift.
Red line that bitch!
Old 05-26-2008, 06:14 PM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
ok but everytime i redline it seems like it loses power.. cuz ive always heard after a certain rpms your not doing anything and i didnt want to get my **** kicked to bad so i wanted to play it safe
but even if i did redline it.. i dont think that would of made a differance...
Old 05-26-2008, 06:30 PM
95to96transplantneon's Avatar
95to96transplantneon is offline
its hard to say josh... you thought you were going to get spanked... with that small of a difference its purely driver adjustment... if you wold have launched better and shifted the same way in either race you would have had him... and it may not seem like your making power but what your going for is for when you shift to second its still in the power band....
Do me a favor... go over to busters and check the timing and make sure that the exhuast cam isent like a half to a full tooth off... sounds like the overlap is a bit small... that there would be enuf to steal a few hp... With this set-up you should check the timing about 300 miles or so after install... have buster help you since its a touchy thing and 2 sets of eyes are better then one...
and the nice thing is that the 2.4 is non-inerferance so if the timing belt does go it wont smash the **** out of the valves... but just check it for me... it could be causing a power loss...
Old 05-26-2008, 07:55 PM
JackMehoffer69
What Jeremy was getting at but didn't finnish is that even though you may not feel like red lining it is going faster it will be faster since your in better position for your next gear which keeps you in the powerband the whole way.
Old 05-26-2008, 08:21 PM
yeah i have a tendonsy to do that...
its hard to explain... josh...
By staying in gear longer when you shift your rpms will be higher in the power band meaning it will be making more power and wont take as long to get going... If you shift early the rpms will be lower and you will have to stay in the gear longer to get it into the power band where its making the most power it can... in the long run it takes the motor longer if the rpms drop to get to peak power...
I realize your not making power all the way up there but its a shorter amount of time your out of the power band then if you shifted earlyer and had to bring the rpms up from a lower rpm...
Old 05-26-2008, 10:29 PM
JackMehoffer69
ORIGINAL: 95to96transplantneon
yup, also he's probably making more power past his red line than he would if he shifted earlier and dropped down to 3500 Rpm. On my dohc mtx Neon the RPM's never drop below 5200 Rpm.
Old 05-27-2008, 12:56 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
Told ya it would be close. Some tuning, and you'll have him. Good run for starters.
Old 05-27-2008, 12:59 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
I cant get the links to work grrr
Old 05-27-2008, 02:32 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
hmm the links seem to be working for everyone else
so today i redlined it at 6500..? i though with MPP the rev
7600 rpm on the DOHC.
and i was in second and i seemed to lose power at 6 but i understand the next gears power band thing..
ok just to straighten things out i should take it to the Rev limiter (redline) just making sure there the same thing ...
i think i got shafted if im spitting out at 6500...[>:]
Quick Reply: finally race the Crx check it out
