EGR Valve
Old 01-24-2010, 09:48 PM
95neoncoupe's Avatar
95neoncoupe
95neoncoupe is offline
Default EGR Valve
On a 95 neon does it make any difference with or without the EGR valve on the car. I have heard both ways, yes the car will run fine or no it will run like **** can anyone confidently give me an accurate answer. Thanks
Old 01-25-2010, 09:24 AM
das2123's Avatar
das2123
das2123 is offline
No matter the year, the neon will run fine without one. You may or may not get a code for it though. There have been several reports with no CEL and some who do. You will need to block of the EGR ports on the head and underneath the TB or you will experience vacuum problems.
Old 01-25-2010, 06:19 PM
1fast2liter's Avatar
1fast2liter
1fast2liter is offline
no effect in its running mopar sold the block off kit for years... now you can make ur own... or slip in a dime up by the tb were it goes in... thats the cheap way if you want to remove it by a kit and you can remove the whole system...
Old 01-26-2010, 01:04 AM
95neoncoupe
ok this is kind of off the topic but what is the best e85 setup for a 1st gen neon. Is their a kit you can buy? I attempted to look around on the web an the ones i saw didnt look legit
Old 01-26-2010, 04:06 AM
1fast2liter
eaither mega squirt and go that route.. or i think bigger injectors like 24# and a boost in fuel pressure by a returnline kit mite do it.... ms was the easist way to do it no injector change a straight map for regular fuel and then one with more timing and fuel for e85 so you can switch to eaither when ever... no returnline needed and allows you to adjust pulse width on the injectors...
Old 01-26-2010, 10:23 AM
95neoncoupe
ok so if i went the route of the 24# Injectors and the return line kit i wouldnt need to do any mods or upgrades to the fuel pump or the fuel lines or anything woud I.
Old 01-26-2010, 10:33 AM
circumventor's Avatar
circumventor
circumventor is offline
idk way yall wanna take off egr if yall understod what it dose how it works and when it comes on yall'd see that it dont have no efect on power cuz it only comes on during hot cruse and off at idle, cold and wide open. it lets the engine run leaner duing cruse for better fule milage
Old 01-26-2010, 10:50 AM
das2123's Avatar
das2123
das2123 is offline
It also puts all kind of soot into your TB and intake.
Old 01-26-2010, 12:51 PM
circumventor
idk how it would put soot in teh tb cuz the egr aint going into the tb. i got race carbed motors that dont have egr and they get sooty look in the intake too.
Old 01-26-2010, 01:00 PM
das2123's Avatar
das2123
das2123 is offline
Seriously?
Look at what it's called, Exhaust Gas Recirculation Valve. The EGR tube connects right at the bottom of the TB. Look at the bottom of the butterfly plate. This also allows soot to gunk up the intake.
Quick Reply: EGR Valve
