AHH My fog lamp is out!
Old 05-19-2005, 05:58 PM
matpro's Avatar
matpro
matpro is offline
Default AHH My fog lamp is out!
My fog lamp on the passenger side....it burnt out...Changed the bulb....still no light....i checked the bulb that i though was burnt..and it looks fine....what can i check....ive checked the wire that goes from the fog lamp to another box seems ok.....what can i do????
Old 05-20-2005, 05:38 AM
casper's Avatar
casper
casper is offline
Default RE: AHH My fog lamp is out!
Try buyin a meter and goin to town, thats the unfoutunate, only answer.
Old 05-20-2005, 06:25 PM
ClearD's Avatar
ClearD
ClearD is offline
did ya check the fuses? or does one fuse control both lamps?
Old 05-26-2005, 03:18 PM
matpro's Avatar
matpro
matpro is offline
Didnt get the chace to check the fuses yet will do that tonight....Also checked withvolt meter....no power...but if fuse is out = no power...ill check tonight
Old 05-27-2005, 02:04 PM
matpro's Avatar
matpro
matpro is offline
Checked the fuse.....Its good...One fuse for both lights...one working the other no.......HMMMM
Old 05-31-2005, 11:20 PM
ClearD's Avatar
ClearD
ClearD is offline
can you trace the wires through to see if there's a faulty connection anywhere? I mean like...past the box...or maybe there's a loose wire there...look for a possible loose ground, cause that would cause it probably...not sure what else...
Old 06-01-2005, 12:40 PM
highrevr/tflea's Avatar
highrevr/tflea
highrevr/tflea is offline
This may sound stoopid but most chryslers need the wierd grease at the end of their bulbs in my sundances front lights with the metal capped bulb it required grease. I never looked at my foglights on my old R/t to be able to tell you if that is the case on these. And One short in a light on a certain side can cause it not to work on the other side. Or at least thats how it worked on my old car. Never had a problem w/ it on the neon. Just on my sundance so dont quote me on this.
Old 06-06-2005, 01:16 PM
matpro's Avatar
matpro
matpro is offline
Ill trace the wiring this weekend...check the grounds...i have the haynes manual with wireing diagram...ill check it out.....i have already check the easywireing...that is visible nothing wrong...ill check the rest....
Old 06-06-2005, 05:55 PM
ibrox_2000's Avatar
ibrox_2000
ibrox_2000 is offline
This exact problem happened to me about 4 weeks ago. I checked all the wiring the same as you, it
turned out to be a build up of rust in the connector. I cleaned it out and havent had a problem since.
Good Luck.
Old 06-07-2005, 11:25 AM
matpro's Avatar
matpro
matpro is offline
What connector...the actual.....connector to the bulb ?
Quick Reply: AHH My fog lamp is out!
