smoke....ONLY at idle???
ok so i just picked up this 96 neon highline (expresso)....everything seems ok except for the fact that the passenger side motor mount it shot so the motor clunks around in between shifts...AND my main concern....if i let the car idle for about 5 to 10 minutes...it barely starts to smoke out the exhaust....then when i rev it up holy SMOKES!! all pun intended. Its like a locomotive...but it stops after about 10-15 seconds and doesnt do it any more at all while driving...doesnt matter if its stop/go or freeway there is no smoke at all. What could be causing this. Like i said it only does it if i let the car sit and idle for about 5 minutes..then when i take off it smokes bad then all of a sudden just stops. Thanks for your help.
***Anybody got a spare passenger side motor mount laying around for a MT dohc? Thanks!!!***
RE: smoke....ONLY at idle???
I can only guess what problems you're running into concerning the smoking issue.
About the side motor mount issue, I'd consider getting a replacement set of all of your motor mounts done at the same time. Howell automotive has them available online here or you can find them at NAPA, Partsource, or similar.
ORIGINAL: whyte69
.....or you can find them at NAPA, Partsource, or similar.
Trending Topics
