No spark on spark plugs HELP!!
Old 03-11-2006, 11:01 PM
coocoobird's Avatar
coocoobird
coocoobird is offline
Default No spark on spark plugs HELP!!
Hey everyone new here.
I have a 97 neon DOHC. I cant get fire to the plugs. So i tried 2 other coil packs from a Junkyard and still nothing. Could the only thing left to change out be the computer? or doesnt the crankshaft and camshaft sensors have anything to do with it?
Old 03-11-2006, 11:15 PM
highline95jl's Avatar
highline95jl
highline95jl is offline
Default RE: No spark on spark plugs HELP!!
Actually its probably the coil packs youve tried to replace it with, god knows where theyve been or when they were put on the car, kinda just like me with my recent alternator situation, I tried saving some money by buying it there but all of them were ****. Youre really better off buying a new replacement, do that before you go spend 200 something on a new PCM.
Old 03-11-2006, 11:18 PM
coocoobird's Avatar
coocoobird
ORIGINAL: highline95jl
any way to test the coil packs? Some people say yes some say no.. but i dunno!
Old 03-11-2006, 11:21 PM
highline95jl
the best way to test them as far as I know is putting them on your car. Have you tried new plugs also.
1st Change your wires and plugs, make shure you buy copper plugs because platnum is useless on the neon.
2nd Coil Pack
Do that before you go waste a rediculous amount of meony.
Old 03-11-2006, 11:25 PM
coocoobird's Avatar
coocoobird
2nd Coil Pack
yup new plugs and wires. =(
Old 03-11-2006, 11:28 PM
highline95jl
ok well im positive your salvage yard has a return policy and I hope you still have the reciepts, take those back, and put in a NEW coil pack first before you freak about anything, keep us posted [sm=smiley20.gif]
Old 03-11-2006, 11:33 PM
coocoobird's Avatar
coocoobird
yea actually ive tried 2 coils from the junk yard lol no go on that.
Old 03-11-2006, 11:36 PM
highline95jl
I highly belive that your used coil packs are a problem. You can pick one up from auto zone for $25 bucks, nothing fancy, but it does get the job done.
Old 03-11-2006, 11:53 PM
coocoobird's Avatar
coocoobird
i only have 1 coil pack and its 80$ at autozone .. but ill try that. But i have extra money to get crankshaft and camshaft sensors. If those go out does that cause it to not fire? I checked trouble code and i got a code 11 blink once then pause then blink once again. I dont have a fancy scanner for it.
Old 03-12-2006, 12:17 AM
highline95jl
Code 11:Timing belt skipped 1 tooth or more from initial learned value; Intermittent loss of either camshaft or crankshaft position sensor;
No crank reference signal detected during engine cranking
This probably means you need to replace your sensors, theyve been disconnected, or frayed somehow so that they are not totally functioning. Also possibly time to replace your timing belt.
Quick Reply: No spark on spark plugs HELP!!
