1st gen PCM interoperability
I have 97 SOHC Neon with ATX.
I might be needing a new PCM. Called dealer, they quoted $445 + tax. They also said PCMs are NOT interchangeable between different years and it even makes a difference when the PCM was manufactures.
I'm sure there are some small differences in PCM, but if i get a PCM from a 96 SOHC with ATX, will i have problems?
RE: 1st gen PCM interoperability
ORIGINAL: neoncrazy101
have u checked the fan relays?
Get a PCM from any 97-99 SOHC ATX neon and you will be fine. Costs about $30-$50. You could use a 96, but you would have to swap the pin to activate the fan, so I'd suggest staying away from it.
Trending Topics
