Front diff question
I believe that the one tons use basicly the same frame dimensions that the halves do. I know the cummins used a heavier frame and such. But the best way to know is measure the width of the saddles, and compare it to your springs. Measure center bolt to center bolt on both and then compare steering connection.I believe its a dirrect bolt in but I would make sure before I begin wrenching. If your putting a 60 up front, what ya planning for out back?
I will start by apoligising if you have posted something about this in another thread which I have not seen. But I have never heard of anyone using the dana 60 in a half ton, unless you have swapped this item in previously. The W150 normally used a 9 1/4 rear with 5 bolt 15 inch rims. The 60 is used in 3/4 ton and has 8 bolts and 16 or larger rims. So unless as I have said, you have swapped rear ends, I would make sure which axle you have. Now, as I understand it, Dodge also used a few of the 9 1/4 rears in the D200 which was a light duty 3/4 and used a semi floating axle which I understand will swap with the half ton 9 1/4. However you would have to swap brake backing plates and all hardware. Now, if for some strange reason you happen to have a dana 60 which has been modified to take a 15 rim, I know Ford ran a simular axle in the 80's, a semi flaoting 3/4 that should be able to be swapped in to match the 8 bolt rims on your dana 60 front.
I would say that you have a 9 1/4 from your photos. Here is another guide to take a look at. To be positive though you could crawl under the rear of the truck and look at the webs extending off the center section towards the axle tubes. The dana will have a '60' stamped into the metal. I believe it is on the drive shaft side on the upper right corner but it's been awhile since I was checking one out so I could be mistaken on the location.
Trending Topics
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
