Brakes Pulsating
Brakes Pulsating
My 88 D100 began to sway a little in the back end as well as bounce more than ever. So I began examining the shocks and found the old Monroe's to be very worn, so I replaced then with KTB Excel's. Once I had that knocked out, I began to feel more tire bounce at 50-55 mph, so I had the wheels balanced....all was well.
But...my brakes didn't feel right, the rear would grab at times with no rhyme or reason. So my buddy took off my drums and calipers and we inspected and bled the system. I found that I did not have much pad nor shoe wear...still around 60% or more remaining. But, my roters and my drums were bad...so I replaced both. I also needed to replace my calipers.
Here's the issue now...
When I start out each morning, the brakes work fine, but the longer I continually drive it, the more it begins to pulse whenever I press the brakes. My pedal feels normal. If I drive it to work (20 minutes) the pulse is somewhat noticeable. If I drive it for 45 minutes plus, the pulsations are more obvious and noticeable. Darn distracting.
I could use some insight folks; do you think it may be that I should have went ahead and replaced pads & shoes even though my wear wasn't much; could it be that my replacement drums need to be turned to make sure that they are exactly as round as can be; could my self adjuster system be out of whack, or what other options are left??
Thanks in advance for your help!
Thanks for the help. The pulsation was coming from the back. I did purchase 3 different sets of after-market drums and none would stop the pulsating...it actually got worse. I ended up going to a salvage yard and pulling an original set of good drums off of a 1989 D150 and put those on my D100. It works like a charm....no more pulsating at all. Go Figure that one out!!
I'd love to hear anyone's advise on why the old original drums work over after-market. I even used calipers to measure any differences between the two, but from measurements alone...I could not determine any tangible different between original and after-market,
Thanks everyone...appreciate the help
I have been struggling with the same problem. i notice mine when i am coming to stops from the rear. feels like I am on a bumpy road. i have swapped two sets of aftermarket drums and the problem is still there. i am going to have the set I have now turned to see how out of round they are. The only other thing i notice is the way they set on the wheel studs. They have a bit more play than the stock. perhaps they are shifting slightly when I tighten the wheel down on them and making them off center. What ever it is it is driving me crazy. i thought it was a bent rim for sure.
Trending Topics
Crap drums
The one I bought and started turning, in the picture, was so bad I gave it back to them.
