Bought an 88 D250 to fight boredom
Still struggling with it dying on take-off.
Think I’ve found all the vacuum leaks, and it idles nice, but if I stop it dies when attempting to accelerate from stop. He’ll start right back up.
back to investigating the quadrajet tune…also, is there another little filter in the cylindrical space where the gas line enters?
Oh - on the original fuzzy crumbly headliner, liner, I brushed off the loose dust and put a couple coats of clear paint on it attempting to seal it up. That seemed to wrk OK then I used spray glue to adhere the fabric. I had a partial can and 1 coat didnt stick well enough. I purchased a can of 3M77 and that worked really well sticking the foam backed fabric to the old liner.
Now need to clean the seat, seatbelts, and carpet.
You need to wire brush all the old foam off before you put the new fabric on it. Cigarette smoke breaks the foam down and if you glue to the old foam, when i comes off, there goes your new headliner.
Think I figured it out!
I chased a few vacuum leaks, adjusted the carb with a vacuum gauge and set the idle with a tach, he’d idle beautifully but when I put it in gear, he’d stall and die. Started right back up every time.
I pulled the #1 and #2 plugs and was super happy to see their condition.
Convinced it was a fuel issue, I changed the fuel filter - again. Thought maybe I was pumping debris from the tank.
The I decided to see if the fuel was taking the path of least resistance and flowing back to the tank in the return line instead of pushing up to the carb.
I pinched off the return line with a vise grip and it didn’t die around the block.
so I disconnected the return line and capped the outlet on the fuel filter. This actually seams to have worked!
Update been a while since I gave one, so here goes
When I was working on the interior, I noticed that after Id left the key on for about 40mins it started but ran terrible. This made me think something electrical was heating up and giving me trouble.
I replaced the ignition coil and seem to have solved the stalling issue. Gus is running like a champ and hasnt missed a step since.
Re-energized with a now strong running engine, I replaced the seat cover with a brand spankin new old blanket and used some pieces of the torn-up one that was on the seat for the door panels.
gratuitous pic here
gratuitous pic here
Next I decided to tackle the bed rust that can been in the previous pics.
I wire brushed it, and brushed on some Ospho. If you arent aware of Ospho - its awesome.
I primed the now clean metal and hand sanded the whole bed to prep for the Raptor Liner.
Really happy with the results. I used the 4qt kit and is was enough, but really would have liked to have one more quart for a little heavier coverage. I went over the rails and used a tape from Amazon with a little wire in one side for a clean edge.
Progress pics and finished bed.
