No Dash Lights
‘87 D150 318
No dash lights at all, making night time driving not so fun. Turn signal indicators on the dash kinda work, but turn signals function fine. All gauges function properly.
All fuses check good. Everything is plugged in behind the dash as it should be (at least it seems to be). I replaced all of the light bulbs, still nothing.
Any hints?
Any hints?
It could be a ground issue. I had that on my 78. Pull the dash out and clean up all the grounds. We put a couple extra grounds wires on also. And then they worked.
Where is it grounded? When I pulled it I only saw the speedometer cable, two harnesses (one on either side) I imagine is for the gauges, and two small harnesses (one on either side) I imagine is for check engine light and brake light illuminator.
Trending Topics
Does your dash have a green circuit board? Or were they not using that system in 87?
The circuit board is brown. I assume you’re referring to the very back of the instrument cluster where all of the harnesses attach.
On mine the dash lights each have their own socket that plugs into that board and draws its power from the board, no wire attached to the socket. There are a few studs with nuts that we put a wire on and ran it a ground. It’s not factory but it worked.
