2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
stuck in park
Old Aug 16, 2009 | 05:10 PM
peanutace's Avatar
peanutace
Cool stuck in park
My 08 won't come out of the gate. lol The car is stuck in park. I've tried the manual over ride in the hand book with no luck. Help!
Old Aug 20, 2009 | 08:41 PM
lxman1's Avatar
lxman1
Site Moderator
First, check and make sure that the brake lights work, if they don't, check the fuse. There is also a cable to the shifter that may have broken.
Old Sep 18, 2009 | 03:32 PM
72combo's Avatar
72combo
Okay now I thought I was stuck in park one time but I had put my car in park with brake on and it rolled back a bit after I let off the brake. When I came back I had a hell of a time pulling the shifter out of park. I didn't think of it till after I was driving about the rolling back put a lot of pressure on the parking pin. Not sure is trannys still work the same these days? What was theproblem anyway?
Old Oct 21, 2009 | 12:16 AM
master tech's Avatar
master tech
Site Moderator & Tech
The new avengers have had problems with the brake lite switches. If the shifter doesn't move on manual override, ck the brake switch. This also the same problem with sebring too.
Old Oct 21, 2009 | 06:00 AM
rzramon's Avatar
rzramon
Hi Friend,
It's better to consult service centre. It happens mainly due to automatic transmission fluid.Filling jiffy lube will be helpful in this regard.
Regards,
Razor
Old Oct 21, 2009 | 10:00 AM
peanutace's Avatar
peanutace
The automatic Transmission "shifter" was broke.
Part # 5273244AJ
Dealer said: Removed shift bezel and found shifter to be broken. Removed and replaced shifter module.
Old Oct 22, 2009 | 01:21 AM
rzramon's Avatar
rzramon
Hi Friend,
So had your problem been solved, if not then what difficulties you are facing.
Regards,
Razor
Old Oct 22, 2009 | 04:23 PM
peanutace's Avatar
peanutace
everythings good now thanks just wish someone would wash the car for me LOL
Old Nov 26, 2009 | 09:15 AM
72combo's Avatar
72combo
Wow is this a common problem?
Old Nov 26, 2009 | 11:16 AM
lxman1's Avatar
lxman1
Site Moderator
I hope not. I would hate for my niece to get stranded somewhere in her 09 Avenger
