I gotta ask....
Old May 16, 2007 | 02:05 PM
Billiam's Avatar
Billiam
Default I gotta ask....
Well after looking around I've noticed that several people around here have a 180 Stat. What are the benifits of this?
Old May 16, 2007 | 02:08 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: I gotta ask....
makes it run cooler. and with my chip I need it.
Old May 16, 2007 | 02:17 PM
chris1974's Avatar
chris1974
if im not mistaken......tricks the computer into advancing timing and adjusting fuel ratio. And oh yeah- engine runs cooler-thats always a good thing!
Old May 16, 2007 | 02:48 PM
Billiam's Avatar
Billiam
Ok, so it run cooler. I see. Its under the radiator cap correct? How much are they?
Old May 16, 2007 | 03:16 PM
Casper50's Avatar
Casper50
No, it's not under the radiator cap. Follow your top radiator hose to where it connects to the engine. It is right under the thermostat housing that the hose is attached to.
Old May 16, 2007 | 03:19 PM
Billiam's Avatar
Billiam
Ah, I see. There I go thinking again. They fairly cheap.
Old May 16, 2007 | 03:21 PM
superdak05's Avatar
superdak05
mine was $8.00 at napa number 530080 but rember you need to take the gasket off the original and instal it on the aftermarket one. plus there is a notch you need to cut into it. but i beleive jet chips have them for sale complete for $35.00
Old May 16, 2007 | 03:25 PM
Casper50's Avatar
Casper50
I think summit has them also but they are up in the $40 range. Get the Napa one and cut the notch yourself.
Old May 16, 2007 | 03:39 PM
chris1974's Avatar
chris1974
actually on the 4.7 the thermostat housing is on the bottom hose. And i dont think it has a gasket. Its an o ring.
Old May 16, 2007 | 03:54 PM
Billiam's Avatar
Billiam
So its on the bottom hose from the radiator? Or its on the engine where the bottom hose connects to it?
