engine shuts down at stop sign/ light
RE: engine shuts down at stop sign/ light
I would get a mechanic and go for a test drive. This will tell you everything that isn't working properly. It could be a possible number of things? Does it Stall or Does it Just Shut off? Maybe you have a bad wire connection somewhere? Coil? Distributer? Etc... Could be anything.
no codes, i have taken it to the dodge dealership and they suggested the IAC but it still does it, and it just shuts down, i will try the engine management relay and see what happens, i have been on other forums and they talked about the automatic shutdown relay but i don't know where it isor really what it does or affects, i have reacently changed the battery, the strange thing is i don't have a check engine light and can't get any codes to even point me in the right direction, still open to suggestion
Trending Topics
this is what happend to me about 2 weeks back...no codes or anything...it would just die.....switched out the engine management realy and the cooling fan realy and the truck ran fine...as sson as it cranked i had a code for cooling circuit failure...so thats how i found out
