Transmissions
Old Nov 19, 2011 | 09:53 PM
  #51
leppy89's Avatar
leppy89
Originally Posted by master tech
If you can and have the tools, replace the case. If not then replace it. Don't try to weld the case. Been there wasn't pretty.
Okay thanks. I'm having problems finding one to replace it with that isn't brand new ( not wanting to spend that much money ) and I found this in the classifieds.
https://dodgeforum.com/forum/parts-s...n-package.html
Will this fit on my truck? I know they have the same engine..
Old Nov 19, 2011 | 10:10 PM
  #52
pecoskev28's Avatar
pecoskev28
i have a 2001 2500 with the 47re, just recently it started acting up. It will go into drive fine but will not shift out of 1st unless i either get it up to over 2700 rpms or so, or if i shift it manually. (it does the same thing going from 1st to 2nd) any help would be great
Old Nov 19, 2011 | 11:55 PM
  #53
master tech's Avatar
master tech
Site Moderator & Tech
You should be posting in the 2nd gen ram section, but I would start by replacing the governor solenoid and transducer.
Old Nov 19, 2011 | 11:59 PM
  #54
master tech
leppy89
Just remember, buyer beware. I have seen problems with a lot of sites. When buying from anyone on any forums.
Old Nov 21, 2011 | 09:28 AM
  #55
DakCC4x4's Avatar
DakCC4x4
dakcc4x4
You may have bad seals. You can try seal softer. And see if that helps.
You mean as in the seal between the tcase and tranny or some other ones? Is this a potentionally catastrophic problem?
Old Nov 21, 2011 | 09:43 PM
  #56
Ned's Avatar
Ned
Cant thank you enough for all the info! I have a 00 dakota quad cab 4x4 with a 4.7 and an automatic. Would love to take it on a jeep trail or two but I am scared to death of damaging the tranny. It already shifts hard sometimes and after coming to a stop( maybe a second or two) i feel a light clunk from the tranny. Its a different clunk than a u-joint. Feels like its coming from the tranny itself. I am so paranoid about automatics! Any info would be greatly appretiated!!!
Old Nov 25, 2011 | 10:44 PM
  #57
master tech
DakCC4x4
I was saying about seals inside the transmission. Not the seal on the extension housing and transfer box.
Old Nov 25, 2011 | 10:47 PM
  #58
master tech
Ned
There a few things that maybe causing the sound. The backlash in the rear diff, the transmission solenoid pack or the park sprocket on the output shaft, which is normal.
Old Jan 1, 2012 | 09:32 AM
  #59
1986JEEP's Avatar
1986JEEP
Default Need to help a friend.
He has a 98 3.9 auto that wont shfit out of 2nd even it you run it the gears by hand.
Old Jan 1, 2012 | 06:25 PM
  #60
billetdakota's Avatar
billetdakota
will a 5.9l transmission fit in place of 1997 3.9 L transmission? In the process of swapping out the 3.9 to a 5.9 and figured I'd go ahead and swap out tranny.
Also do you know if the 3.9l differential 2wd is the same as the 5.9l differential 2wd???
