Thermostat housing bolt size - HELP!
Old 11-22-2012, 04:23 PM
JackTheStripper5.9's Avatar
JackTheStripper5.9
JackTheStripper5.9 is offline
Default Thermostat housing bolt size - HELP!
So the last time I did my intake, I broke off one of the thermostat housing bolts while removing it and had to have it drilled out. Was doing my thermostat again and when I went to install the housing, the threads stripped.
Does anyone know the thread size of the bolts? Google isn't being my friend today. Could only find info on the old style V8 and the 4.7s. I have a 5.2 Magnum.
Help would very much be appreciated so I can find the next size up and tap it out. My truck isn't doing me much good with coolant pissed out of the thermostat housing
Old 11-22-2012, 04:47 PM
Wes Garrett's Avatar
Wes Garrett
Wes Garrett is offline
i wish you luck man, im having issues with exhaust manifold bolts...
Old 11-22-2012, 05:05 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Exclamation
can’t help ya but the thermostat housing is only snugged down very little force is needed actually I just barely snug them in and rely on the sealer more than the bolts why you ask because if too tight you warp them and you can strip the soft aluminum out.
Old 11-22-2012, 05:14 PM
JackTheStripper5.9
I know, I barely had it snug and it just spun right around. I tried using loctite and getting it as snug as possible before it spun around and it leaks. I could always just jimmy-rig it using RTV and hope it works but was more or less hoping I could just tap it using the next biggest size.
Old 11-22-2012, 05:19 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Dodge Forum Moderator
Going by memory, I'd say they're either M8 or 5/16". For either, the next size up would be 3/8". What size wrench/socket do they take? 1/2"? 13mm?
Old 11-22-2012, 05:20 PM
JackTheStripper5.9
It's a 13mm bolt head
Old 11-22-2012, 05:25 PM
Tom A's Avatar
Tom A
Tom A is offline
Section Moderator
Then it's an M8 bolt. 3/8" or M10 is a pretty big jump (M9 is kind of an oddball size). Better to heli-coil it, IMO.
Old 11-22-2012, 05:36 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
taping to a larger bolt is fine just dont start to small or you could have the same problem match hole size to tap
Old 11-22-2012, 05:45 PM
JackTheStripper5.9
So I guess I should go with an m8 thread insert....
Old 11-22-2012, 06:40 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I found this it may help decide what size you need.
This depends on what is available to you in stores also
LINK
found another one LINK
One more LINK
Quick Reply: Thermostat housing bolt size - HELP!
