Need help!.. TPS or iac problem?
I hav a 2000 dodge dakota.. Recently installed a used engine with 70k miles.. Truck will run fined for a while then I will get the check engine light on and will get stuck in 2nd or 3rd.. Also will shift hard into reverse and drive.. Has a new fuel pump.. New pugs.. I installed my old TPS onto newer engine.. Ran with no problem for about a week til last night then same problem.. I'm thinking its a sensor problem.. Maybe o2 sensor(s).. Would appreciate some help and suggestions.
The IAC is for your idle only now if its stuck open or closed then possibly it could cause problems
But it controls your idle nothing more
IAC = Idle air control
If bad you would notice idle problems
Trending Topics
P0700 only indicates that there is a transmission code present. You need to get it read by a dealer or a shop. A regular code reader won't do it.
From the FSM:
This SBEC III or JTEC DTC indicates that the EATX or Aisin controller has an active fault and has illuminated the MIL via a CCD (EATX) or SCI (Aisin) message. The specific fault must be acquired from the EATX via CCD or from the Aisin via ISO-9141.
From the FSM:
ok.. im not really technical enough to understand the acronyms but i will get it after a little research... do you think faulty O2 sensors could be a possibility? when the check engine light goes off the truck runs beautifully, aside from the strong fumes when starting that i might not have mentioned.. i am determined to get this truck rolling back at a 100 percent.
