front calipers wearing on steering knuckle
Old Oct 27, 2014 | 03:04 PM
kwasiak's Avatar
kwasiak
Default front calipers wearing on steering knuckle
Is anyone else having this problem? I have a '02 Dak with 4.7L 4wd. My Front disc brakes are wearing out my steering knuckle (where calipers pad ride on knuckle). pads are wearing off the metal and making the caliper sit lower on the disk. spring clip is starting to hit the hub on the rotor. Dealer says I need to replace the knuckle $$$. has anyone come up with a better fix!
Old Oct 27, 2014 | 03:14 PM
00DakDan's Avatar
00DakDan
Section Moderator
Any chance you can post a picture?
If you do need a new knuckle, check a boneyard.
Old Oct 27, 2014 | 03:22 PM
kwasiak's Avatar
kwasiak
won't be able to get pic until the weekend, it is basically were the caliper pads slide on the knuckle.
Old Oct 27, 2014 | 05:03 PM
magnethead's Avatar
magnethead
the slide pins?
Old Oct 27, 2014 | 05:32 PM
kwasiak's Avatar
kwasiak
nope, Slide pins are fine, pins are in the back of the caliper.(engine side of caliper)
Old Oct 27, 2014 | 05:50 PM
00DakDan's Avatar
00DakDan
Section Moderator
I think I know what you mean, the edge of the pad rides on a machined lip and the pad is wearing it down.
Are you sure it is not the pads? Maybe the brand you are using just isn't machined properly - it happens.
Old Oct 27, 2014 | 05:56 PM
kwasiak's Avatar
kwasiak
yes the machined surface is wearing unevenly, I just had the pads off, they are fine. you can see the indents in the machined surface.
Old Oct 27, 2014 | 06:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
I've seen vehicles that have a spring type clip that goes over that machined surface for the pads to ride on, not a Dakota, but maybe someone makes something similar.
Old Oct 29, 2014 | 03:45 PM
dbilik's Avatar
dbilik
I'm having the same problem. I swapped out a knuckle with a used one, new caliper, new pads, new rotors. Same thing, so I was under warranty and assumed I may have another bad caliper. Did brakes, rotors, and pads a second time, same thing. I am out there working on it today. The outside of the caliper, side closest to the wheel, dives down and in towards the center of the hub, and the brake pads wear at an angle. It also causes my inner pad to wear faster. Eventually it dives so much that the screw on the retainer clip just barely scrapes the hub portion of the rotor. It actually warped my rotors which is why I am guessing it is caused by the caliper not being allowed to release.
I haven't figured it out, but I am thinking the caliper isn't being allowed to release the pressure inside, and I am replacing the rubber hoses up front to see if it resolves the issue. Problem is, I won't know it isn't fixed until I lose another set of pads and rotors.
I have read that the rubber hoses deteriorate over time and may break down. And actually introduce rubber pieces into the caliper itself. I am planning to open it up and see if there is rubber in there. Debating if I swap the seals myself (which I have) or go with rebuilt calipers again. Have a hard time thinking I have had three bad calipers in a row on the left front.
Old Oct 31, 2014 | 05:26 AM
98DAKAZ's Avatar
98DAKAZ
Can you post any pictures or its all bolted back together?
I'm curious I know your disk brakes are different than my 98 disk brakes but I'm Interested in this problem?
