p1698 code,no bus,no working gauges,no start
Old Sep 17, 2015 | 09:31 PM
  #41
frowningdodge's Avatar
frowningdodge
Ok camshaft sensor and crankshaft sensor are good map sensor is sending signal tps is working, intake air temp sensor good,only sensor i could find on motor the engine coolant sensor is bad.that wouldn't cause the P1698 or no bus 920,921,999 would it?
Old Sep 18, 2015 | 07:00 PM
  #42
00DakDan's Avatar
00DakDan
Section Moderator
P1698 is a no CCD message from either the PCM or the TCM.
The 920 and 921 codes are cluster codes, for no distance pulse and speed message from the PCM. 999 is an error has been discovered.
All are related to your CCD bus being shorted out.
This is the worst type of problem to have to find. It can be any of the CCD bus wiring in the vehicle or any of the modules. You need to isolate it as much as possible to find out what is going on.
Old Sep 18, 2015 | 09:15 PM
  #43
frowningdodge
ok I'll keep testing and searching I'll find it.
Old Oct 1, 2015 | 08:35 PM
  #44
frowningdodge
ok bought used pcm and started right up. replaced with warranted new pcm i had runs great . I'm coming up with codes 950,999,abs light comes on and speedometer does not work.Could this be sensor on top of rear end?Or something to do with abs.
Old Oct 1, 2015 | 10:31 PM
  #45
98DAKAZ's Avatar
98DAKAZ
Pull the diff sensor and look at it as it may be trashed
Old Oct 2, 2015 | 04:59 PM
  #46
00DakDan's Avatar
00DakDan
Section Moderator
Cluster code 950 = The cluster is not receiving an ABS lamp-on message from the CAB.
Check the fuses for the ABS.
It can also be a CCD bus problem.
